Prepass and scale rules when entering different states?
Discussion in 'Questions From New Drivers' started by TawcoTruck, Feb 11, 2023.
  1. TawcoTruck
    TawcoTruck Light Load Member
    155
    224
    Dec 11, 2022
    It looks like we're going through a few states and the truck is equipped with prepass.
  3. Terlingua
    Terlingua Medium Load Member
    487
    1,019
    Oct 24, 2021
    Don’t go in if you get the green light?
    Bean Jr. and Milr72 Thank this.
  4. MACK E-6
    49,277
    230,758
    I always wonder about that. I’ll skip it if I get the green light on an Interstate, but I cross several scales regularly on full access highways where they love to chase people down.
  5. Milr72
    Milr72 Medium Load Member
    571
    1,388
    Dec 16, 2011
    S W Missouri
    If your pre-pass tells you to keep going you don't have to stop, but if it says stop, that's what you do.
    RockinChair, Bean Jr. and ducnut Thank this.
  6. TawcoTruck
    155
    224
    Dec 11, 2022
    Does anything supercede the green light?
  7. beastr123
    beastr123 Road Train Member
    2,887
    23,683
    Jan 2, 2014
    Moose Jaw SK CAN
    Oversize loads are required to stop regardless of prepass signal.
  8. kwswan
    kwswan Road Train Member
    1,962
    10,486
    Jul 26, 2009
    mcminnville,tn.
    Haz mat as well.
  9. Arctic_fox
    4,207
    22,109
    Sep 16, 2016
    A basic general rule is if they have a sign and it says stop not just open or whatever then you stop otherwise green light means go unless other conditions as above apply. You CAN likely run a scale with a green light even if the sign says truck must enter scale...... but your tempting fate at that point. Moreso of the trooper is particually assholeish.
    TawcoTruck, nredfor88 and motocross25 Thank this.
  10. Moosetek13
    Moosetek13 Road Train Member
    14,739
    18,568
    Nov 1, 2010
    Burnsville, MN
    I have entered when I got a green light but the sign said to pull in.
    I went in to ask and was told that if I got the green light I did not have to come in.
    TawcoTruck, Coover, Rickp and 3 others Thank this.
  11. kemosabi49
    10,739
    46,246
    Jan 13, 2013
    SW Arkansas
    Best to get correct info from the PrePass pamphlet or you can likely get it online. In some states, Arkansas and Arizona for sure and I'm sure some others, If you are placarded you must go into the scale, green light or not. And I don't get out west anymore so I don't know about Arizona, but Arkansas will come after you a lot of the time. Friend of mine got nailed and the fine was @ $150. Most of the others you can bypass with placards, but if you're not sure better to go in.
    tscottme, TawcoTruck and D.Tibbitt Thank this.
