Pressure modulation valve ABS error
Discussion in 'Volvo Forum' started by volvoworld, Jan 14, 2014.
  1. volvoworld
    volvoworld Bobtail Member
    4
    Can anybody help me out with ABS problem on Volvo FH12 2004
    Pressure modulation valve ABS axle 1 left and right communication error
    MID 136
    SID 7 and 8
    FMI 2
    How can I troubleshoot this?
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    Have you checked electrical connection at the valves?. Pulled electrical connectors checked for corrosion on the pins?. Corrosion in the connectors. Is the wiring intact not cut ar broken wire. I ask because i've had similar codes in a different trk and electrical connectors were corroded. Cleaned them up put some dielectric grease in connectors. Pulled battery cables for about 10 min and codes never came back.
  4. volvoworld
    4
    Do you mean electral connectors to the valves or to the ECU because this error are active on both Left and Right axle.
  5. jason6541
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    Valves mounted on frame rail. Not sure which system you have 2 channel,4 channel. Not familiar with your trk but generally abs systems same from trk to trk, limited manufacturers
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I sugest he got early EBS system, so things are different a bit.
    ABS sensors are not connected to MID 136 unit, they are connected to EBS modulator and it sends data to EBS central computer by Brake CAN
    So I'd start with vehicle identification
  7. volvoworld
    4
    Thanks guys for all response, Vin number for this truck YV2A4CEDX4A586539 if that helps.
    I don´t know where I should start to troubleshoot.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    looks like a wiring problem. Front axle modulator valve power supply broken.... usually under cab
  9. volvoworld
    4
    Thanks Pablo for quick reply, do you have any diagram for this system.
  10. gogy123
    gogy123 Bobtail Member
    Hi guys. I am new to the site but have a similar problem with a 2002 FM rigid lorry. Code mid 136 sid 9 fmi 9 appeared recently and brake ECU failure is showing on screen. Does the pressure modulation valve need replacing or is it wiring? I have checked connections from sensors to valve with no obvious issues evident. Any help greatly appreciated!
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    rear axle left abs modulator failure
