Pressure washer for garage.
Discussion in 'Ask An Owner Operator' started by slavcha, Mar 6, 2013.
  1. slavcha
    slavcha Light Load Member
    151
    133
    Oct 17, 2011
    Utica NY
    Can some one sagest good pressure washer for washing truck. I usually get home once a week, and can drop a trailer and bobtail home. Would like to buy a pressure washer i can keep in garage and use it to wash my truck. Blue beacon getting to be lill expensive. Thanks for all suggestions.
  3. EverLuc
    EverLuc Light Load Member
    295
    101
    Feb 18, 2013
    Honestly, the only time I use the pressure washer is when I wash out thee trailer. Once every few months I use it on the under carriage. A hose,bucket and that heavy duty telescoping pole brush do the job great. Plus no noise. I own a Briggs/Stratton setup 3.5hp and a CambelHausfld. Both work great.
  4. Studebaker Hawk
    Studebaker Hawk Road Train Member
    2,970
    9,570
    Oct 18, 2010
    NW Indiana
    any number of units will do the job. I like the one I have powered with a Honda engine. starts everytime. I think a pressure washer properly used has it's advantages over just a brush and a bucket. And I stopped using Blue Beacon in 1982 after they destroyed the paint on my 2 year old tractor. Why do you think they call them streakin beacon? If you rely on pressure and harsh chemicals alone you are going to harm the toughest finish.
    2 nd advantage of a pressure washer is sometimes in the winter I don't want to wash the entire truck sparkling clean, just get the salt off of it. And of course it is a necessity for the chassis, hand washing there is totally ineffective.
  5. MsJamie
    MsJamie Road Train Member
    Whatever you get, make sure it's high pressure. 2500 psi is the minimum I'd consider. We have a 2200 and it's marginal.
  6. TruckingSurveyor
    TruckingSurveyor Light Load Member
    133
    43
    Jan 28, 2013
    Oregon
    I bought one from http://www.pressure-pro.com/, I wanted a Honda Industrial motor (buy a GX and NOT a GC series) AND a CAT pump, so that was my criteria in shopping, really they are all a frame with an engine and pump, kind of like a CMV, you can have a Honda or a Briggs engine on a manufacturer[FONT=arial, sans-serif][/FONT]of your choice. I got a 2700 PSI because the soap and aluminium cleaner I have recommended something that strong, you are going to have to pay a bit more to get a stout one, mine was right around $1K. I also recommend a piston pump over a radial one.
    You didn't ask, BUT the best soap and cleaners I have found are from http://www.tetra-chem.com/, I use the TCI710HD and the TCI503HD, both are the bomb. The dealer I used to buy from was in Ohio, BUT I think he moved to Florida and retired, his website seems to be dead.
    TS
    Cowpie1 Thanks this.
  7. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    I used to use a pressure washer, but found that using the local car wash in town when I come home was a better option. I could leave the mess with them. And it was hot water for the wash/soap part of it. I know that this is not an option for everyone. Fortunately, I have local car washes in two towns near me that have bays large enough for truck tractor.... at least half of it at a time.
    If you are wanting serious wash setup, the best one, and of course the most costly, it one of the Hotsy units. You can get small scale units, and they will wash the dried feces off the back end of an elephant in quick order. And there are all electric versions. Other wise, check your local farm and home store, or local building supply for a regular pressure washer. There are a lot of options. TS offered what seems like a viable option.
