Primary filter base
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Sodapop, Oct 27, 2013.
  1. Sodapop
    Sodapop Light Load Member
    93
    7
    Mar 19, 2010
    Blytheville,Ar
    I am adding the old style canister f/w separator on my 04 379 pete. I have a Fuel filter fitting( fuel filter vac guage) that hooks in to the filter base lines, which side of the filter base does the fitting go. TY
  3. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Good Morning SP:
    If i understand the question... the gauge will install on the "out" side of filter. This allows gauge to "see" filter restriction...
    :biggrin_25514:
  4. SL3406
    SL3406 Medium Load Member
    550
    1,492
    Jan 10, 2011
    Oklahoma
    It should go on the outlet side of the filter to measure the restriction of the filter.
  5. Sodapop
    93
    7
    Mar 19, 2010
    Blytheville,Ar
    thx guys, yes it is the fitting/hose that connects the gauge in the dash....I thought that was right Peterbilt shop foreman told me the other way. But that wouldn't make any sense..Thank you sirs
  6. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    The filter should be installed between the fuel tanks and the fuel pump. The gauge should be on the fuel pump side of the filter.
