Prime's 2011 Freigtliner Cascadia Lightweight
Discussion in 'Prime' started by 4Given, Mar 27, 2011.
  1. 4Given
    4Given Bobtail Member
    I just wanted to give a little warning for those who drive the 2011 Freightliner Cascadia Lightweight.....make sure you keep an eye on your wheel seal and hub caps!! Today as I was doing my normal walk around while fueling, I noticed my left rear drive was severly leaking. It was so bad that the tire itself was covered. In addition, I also noticed both of the steers are leaking as well. This was something that must of occured between my pre-trip and when I noticed it, because the problem was not present when I conducted the pre-trip.
    I just thought I pass the word....ya'll be safe out there.
    ledzeppelin Thanks this.
  3. U2Exit
    U2Exit Road Train Member
    2,353
    1,051
    Feb 22, 2008
    WA and VA
    Its more than just a Lightweight truck issue. They have been talking
    about this problem for a few months on the Safety CDs, on-hold messaging.
    Each truck has been flagged to be checked at its next PM. Word should have come down from you RA manager to keep on eye on those seals.
  4. TruckerMike
    TruckerMike Medium Load Member
    420
    266
    Dec 20, 2008
    Chicago
    My 08 Century has had the same problem. I've had the same drive wheel leak twice in the last year. Luckily, each time I've caught it early enough and it was a quick 15 minute repair. But like your leak, mine was substantial. Enough to not only cover the rim and the tire, but it was actually pooling in the rim as I was looking at it! :biggrin_25524:
