Printer and power inverters?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by DDlighttruck, Aug 2, 2016.
  1. DDlighttruck
    DDlighttruck Road Train Member
    1,386
    19,919
    Dec 12, 2015
    Any reason why my printer works from a standard wall outlet, but not my power inverter? 2500 watt cobra, runs an 800 watt microwave no problem. It's just a small portable Brother printer, the size of a very small duffel bag.
    I'm guessing this might be the sine wave/modified sine wave issue?
    Any way to make this work?
  3. Espressolane
    17,509
    107,179
    what model printer. my epson worked on a 150/300 watt unit.
  4. DDlighttruck
    1,386
    19,919
    Dec 12, 2015
  5. DUNE-T
    DUNE-T Road Train Member
    6,943
    16,843
    May 10, 2015
    Detroit, MI
    I guess you checked and it works with standard wall outlet?
  6. DDlighttruck
    1,386
    19,919
    Dec 12, 2015
    Yes, thank you. Worked fine at home. Threw in truck. Didn't print. Called tech support. Took printer and laptop in to the break room at shippers. Printed fine.
    Tech supports conclusion: power inverter.
    Edit: I didn't THROW it in the truck. Before someone says anything. I gingerly placed it on the passenger seat.
    alds Thanks this.
  7. DUNE-T
    6,943
    16,843
    May 10, 2015
    Detroit, MI
    No idea, I have fridge, microwave and printer running of the same inverter what you got
    DDlighttruck Thanks this.
  8. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    173
    Oct 29, 2014
    Carlingford NB Canada
    Try
    Plug printer in
    Start toaster
    Try to print
    I got a acer power adapter who works only afterbi use onetime a high power consumer
    Maybe the poweradapter have a prob with the
    Sinus wave
  9. DDlighttruck
    1,386
    19,919
    Dec 12, 2015
    Thanks. I'll try that.
  10. snowwy
    snowwy Road Train Member
    20,545
    13,280
    Jul 6, 2009
    I"ve been running a 140 watt inverter that plugs directly in to the cig socket. Bought from walmart. Have had no problems with laptop charging and printer printing. Hp also bought from bestbuy 6 years ago. Printer scanner.
  11. Ridgeline
    22,385
    116,219
    It is because of one or another thing.
    First it is them inverter itself, maybe too dirty of a signal on the power line.
    Second it may be the printer power supply which can't take anything but a pure sine wave, which is caused by cheap sourcing on the part of the printer maker.
    Either way there are two options, a good inverter with a pure sine wave or another printer.
    rabbiporkchop and DDlighttruck Thank this.
