Printer options.....
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by bullhaulerswife, Jan 10, 2010.
  1. bullhaulerswife
    bullhaulerswife Forum Leader/Admin Staff Member Administrator
    28,291
    44,450
    Jul 23, 2007
    Midwest
    We are going to start using the laptop for hubbys logs. Having very little space in the truck, I was wondering what printers you guys use and where do you mount them? What type of connectivity do you use. I've been looking at the compact printers, HP makes on, but honestly, I don't think that its worth the price that they are asking.
    Thanks in advance for your input.
  3. RAG
    RAG R.I.P.
    541
    4,922
    Nov 23, 2007
    Tonga
    Bet your Hubby's cab is larger than mine (05 379 ext hood)
    I use a Cannon IP 90
    It's been very tough
    You can find the ink things on the net for cheep
    Keep a few extra as they are very small
    For a mount I use a RAM I think Don at Dieselboss has them
    rag
    bullhaulerswife Thanks this.
  4. CertifiedSweetie
    CertifiedSweetie Road Train Member
    1,489
    1,634
    Nov 18, 2008
    Pittsburgh,Pa
    I bought my printer off ebay. You'll probably be able to find a good one on there for a great price. I have a hp printer scanner copier fax and I only paid $59.00. You could maybe try to get a brand that you know a walmart or target would sell the ink so t will be to find ink. Also if you go to cosco or sams club they have ink in bulk.
  5. bullhaulerswife
    28,291
    44,450
    Jul 23, 2007
    Midwest
    I'm thinking that we might be able to mount it on top of the microwave. We ditched the toaster oven, since we didn't use it but once in about three months.
    Yeah, hubbys cab is bigger than yours. LOL
    Do you have to leave it hooked up, or can you just hook it up when the DOT wants the log books?
  6. RAG
    RAG R.I.P.
    541
    4,922
    Nov 23, 2007
    Tonga
    I don't know
    I still run a three ring binder so I don't do the e-log thing
    I use mine to print permits and maps off streets and trips that I have put my routes in
  7. WingRider
    WingRider Medium Load Member
    542
    426
    Dec 3, 2007
    Salem, OR
    Ive been running Drivers Daily Log for a couple of years now. You have to print out your log each day and sign it, and then keep 7 days available at all times. I am using a Canon IP1800, been working great so far.
  8. Pur48Ted
    Pur48Ted Road Train Member
    3,643
    5,981
    Jun 14, 2006
    Grand Rapids, MI
    I use a KODAK Printer, not sure of the model number, but it is the smallest printer/scanner/copier Kodak has.
    Kodak price is about 30% HIGHER than the comparable HP printer, but INK Cartridge price is less than 1/2 than for the HP (or other brands).
    Other brands build the "printer head" into the cartridge. Kodak does not, so you are paying for the INK and not the printer head.
    I am much happier with he KODAK than I was with the HP.
    I just find an open shelf area for the printer.
  9. freddyweigel
    freddyweigel Bobtail Member
    17
    Feb 2, 2010
    derry,NH
    There is a Cannon battery operated printer real small but goes for 270.00 so I use a 50.00 Epson with cheap cartridges and a 50.00 usb cannon lide scanner. Hook the thing up when I need it. Work pretty good so far, I have a Volvo 780 an I took the cb out off the dashboard and put my laptop closed in there with a 7 inch remote screen for gps.
  10. Markk9
    Markk9 "On your mark"
    1,052
    229
    Nov 26, 2006
    Lehigh Valley, PA
    I use a Canon iP2600 ink jet, it's like $50 at best buy, works great on the truck. I just put a power strip on the inverter. I keep the printer, usb cable and power cord in the original box using the bottom foam for support. When I need to print I just pull out the printer, pug it in the power strip, and plug the USB to the laptop.
    Mark
  11. Blue Screen
    Blue Screen Light Load Member
    127
    108
    Jan 29, 2010
    Atlanta,GA
    Two of my Customers (OTR Drivers) are using HP Officejet H470 printers. You can see them over at newegg. Ink will kill you in the long run. I would hunt a old small laser-jet b/w on e-bay like "Lexmark Optra-E" (ebay $25 toner for 2000+ pages, nice and cheap) Just make sure your windows has drivers for the printer,a good inverter,and a usb parallel cable. This model will work with ME,2000,XP,Vista,& Windows 7. The printer and cable ran me $20 on ebay. Good Luck:biggrin_255:
