1. vinsanity
    vinsanity Road Train Member
    1,760
    689
    Nov 23, 2009
    South Florida
    Did a quick search but couldn't find any recommendations.
    I'm looking for a small printer/copier that can can hold up in the truck. It needs to be wireless so I can use it with my android phone and tablet. Would also like something with ink cartridges that don't cost an arm and a leg.
  3. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    HP2540 Can print direct from phone and scan direct to phone, no computer required. Must have inverter for 120 v power. I paid $39.99 at Bestbuy in Canada.
  4. lastone in
    lastone in Light Load Member
    180
    35
    Apr 5, 2014
    Plano, TX.
    [h=1]Epson Expression Home XP-410 Small-in-One All-in-One Wireless Inkjet Printer (C11CC87201)[/h]
    Available AT AMAZON FOR $69.99
    I have been using it for 2 years now. Works on my iPad and Mac wireless.
  5. snowwy
    snowwy Road Train Member
    20,553
    13,281
    Jul 6, 2009
    most all printers have wireless. and they're cheap and can be found everywhere. i spend $14 for black ink about every 6 weeks. had my hp 610 printer almost 4 years now.
    bad thing about wireless. you have to have internet signal or it don't work. don't know about other brands or models but mine won't connect if there's no internet.
  6. Joetro
    Joetro Road Train Member
    2,416
    2,409
    Aug 23, 2008
    Post Falls, ID
    I had the Small-In-One, albeit, an earlier version. It worked very well in the truck until it took a dive off my top shelf. Kinda stopped working after that.
  7. lastone in
    180
    35
    Apr 5, 2014
    Plano, TX.
    Not 100% correct. You need to get a printer that says something like “direct connect” or “AIR Print” compatible. The older one needed an internet connection, but newer printer can “direct connect” wirelessly without an internet connection.
    This is great for printing with tablets and smart phone’s.
  8. Davidlee
    Davidlee Medium Load Member
    419
    156
    Aug 31, 2012
    A wi fi direct will allow you to print without connecting to the internet.
    lastone in Thanks this.
  9. lastone in
    180
    35
    Apr 5, 2014
    Plano, TX.
    Thanks Davidlee:
    Its trade name is "Wi-Fi Direct" and or "Air Print"
  10. vinsanity
    1,760
    689
    Nov 23, 2009
    South Florida
    I believe I can get around that by hooking up a wireless router so my phone and tablet can be on the same network.
  11. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    If you're tight on space or a storage freak, be sure to take measurements of potential stow area and look at dimension specs before buying. Make sure to get one with scan/copy feature, preferably with a glass-top scanner for multiple small receipts. If you will be printing a lot of black/white look for one where XL cartridges are available.
    Walmart can probably fit your need with their selection. I was of the opinion that air print was a bluetooth technology but it's not. I found I have to fire up my hotspot device so the printer can connect and I can then see the printer with my phone or laptop. But "internet connection" is not needed.
