when shifting a truck why do you have to clutch go into neutral let out off the clutch then clutch and go into the next gear... Why cant you just shift normally like in a car/truck.... Dont be too brutal with your response
Probably a dumb question BUT.....
Discussion in 'Questions From New Drivers' started by ultraclassic, Nov 15, 2011.
Page 1 of 4
Wargames Thanks this.
A clutch brake is what you say when sitting still. Running down the road shifting it's a matter of matching the engine's rotating speed with the transmission's/rear wheels rotating speed. That's why you clutch out, match speeds with the throttle, clutch in, engage.
Cars have what they call synchronizers in the transmission. It's a brass ring with nubs on it in front of each gear. It allows two gears spinning different speeds to mesh. Big trucks don't have synchronizers, so you double clutch to make the gears spin the same speed to mesh. When you hear all that grinding, that is someone trying to mesh two gears spinning different speeds.
Syncronizers are fragile and can break if someone doesn't know how to shift. That's one reason they don't use them in big trucks. There's trucks in Europe and Austrailia that use synchronizers.
To give you a better picture in general, the engines crankshaft extends into the transmission turning the front drive gear. The clutch is in the middle of that shaft allowing the shaft to seperate.
From the backside, you have the rear wheels and differential attached to the driveshaft extending into the back of the transmission turning the other gears.
There's plenty of websites that show you pictures of the inside a transmission or the whole drivetrain to better see how things work. Search out Eaton Fuller or Meritor to see some of the transmission websites.volvodriver01, Wargames, Svoray and 5 others Thank this. -
It's a good question and one I asked during my tour at Truck Driving Boot Camp. The instructors stated that performing a double clutch is easier on the equipment. Everyone teaches it. Only the old timers still float the gears. When I trained I double clutched and my teacher floated the gears. The tractor was a new Freightliner and we both had trouble getting it into gear after switching drivers. Kinda made me laugh when the teacher couldn't get it into gear.
At the school I went to, they just replaced the transmission on one of the trucks. It was real tight, and the instructor also would have problems. It was real picky on the sweet spot. -
http://en.wikipedia.org/wiki/Double_clutch
Go to YouTube, search "double clutch." -
otherhalftw Thanks this.
Mikeeee7122894003481 and red_eye Thank this. -
I would think most exsperienced drivers float the gears. Its so much easier. And as an O/O I say better on the equipment. Well as long as you do it right. You also need to know your equipment. Know what RPM matches what gear speed for the speed of the truck.
Mommas_money_maker Thanks this.
Page 1 of 4
