problem 3406e vs 3406b
Discussion in 'Ask An Owner Operator' started by hotshot89, Dec 23, 2014.
  1. hotshot89
    hotshot89 Bobtail Member
    8
    5
    May 23, 2013
    looking at a few different trucks, most come with 3406b's and the rest with e's I know they are good engines but I'm just curious about the problems I should be expecting, yes I know the E has electrical issue but as with all electrical engines. Being mechanically inclined with these engines is a given as is a must when your an O/O. I am just looking for something's I need to keep my eye on, something's I can do to keep everything work the way they are supposed to, and anything else I should expect would be heplful
  3. Jaxon_allen
    Jaxon_allen Bobtail Member
    Montana
    E model heads are fairly heat sensitive. I ve had good luck with mine, and have alway kept it under 212. It is a tired 550 but working my fan switch in the summer has always done the trick even pulling 110k hay trains up here in montana. The couple times I've popped my alarm off was when I was too late in giving the fan a head start on a three mile hill.
  4. CoronadoDriver
    CoronadoDriver Light Load Member
    182
    30
    Nov 11, 2014
    South Carolina
    the e's are fairly a little older i think but the b's are in newer versions but with what trucks do the 3408bs come with
  5. wore out
    wore out Numbered Classic
    15,364
    185,491
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The B's are older engines late 80's cut off on building them. Then they went to the mechanical C till 94 or 95. There was also an electric C called the PEEC. PEECS scare people to death and most convert them to manual but a few are still around. The thing about a B and mechanical C is there are getting fewer of us dinosaurs around that can work on them. They can be like a Rolex very fine when they are right, but worthless if not set right
    062 and Cetane+ Thank this.
  6. hotshot89
    8
    5
    May 23, 2013
    So the e's are the one sensitive to heat. I read on another post about cracking heads on one of the motors. I read that these motors need someone who knows as my neighbor who pulls hopper with his ford l9000 tells me. I also read something about the water pumps breaking constantly.
  7. wore out
    15,364
    185,491
    Jun 5, 2013
    E is sensitive to heat but as far as water pump trouble I am not aware of any. I mean I have put some on about 100k and some on about 900k. Prob average life is 300k so not bad for a cheap easy repair
  8. 062
    062 Road Train Member
    6,144
    33,186
    Oct 20, 2013
    Don't know if they're more sensitive,or drivers not paying attention,or don't care,or know any better. Both are good motors,the b model you need to leave stock,unless you know how to set the timing and pump. A properly tuned b model will get high 5 to mid 6 mpg grossing 80k If you drive it right.
    wore out Thanks this.
