Problem: Cab extender brackets coming loose from Freightliner Cascadia sleeper
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by makterna, Feb 28, 2022.
  1. makterna
    makterna Light Load Member
    86
    60
    Sep 14, 2021
    My cab extenders, or rather the brackets that hold them, have started to come loose from the wall of the truck. The factory has fastened them with what I think is called "nutserts", threaded inserts that are pushed into holes in the wall. Then bolts secure the brackets to the nutserts. I dont think the nutsert is supposed to deform like a rivet would, it doesnt look that way, so I dont know what is supposed to hold it to the wall, glue maybe?
    The problem is that in my case the whole has grewn (must have been due to vibration over the years) so the nutsert is no longer secured to the hole. The hole now has an oblong shape, like the digit 0 rather than the letter o and I can only assume they werent that shape from the factory. The hole is still 10 mm wide but is now taller.
    Now, who knows the smartest way to repair this? They seem to be 10 mm nutserts with M6 threads, 19 mm deep. What if I order one size bigger, 5/8"? That is approximately 10% bigger according to my calculation.
    Asking Freightliner is never of much help, they always refer to the local dealer, and the local dealer does not know.
  3. p608
    p608 Road Train Member
    2,181
    2,992
    Nov 10, 2016
    Nutcerts are exactly like a pop rivet, the tool expands them in the hole to secure them
    makterna Thanks this.
  4. Val_Caldera
    Val_Caldera Road Train Member
    2,569
    7,937
    Apr 2, 2021
    TARHEEL
    Otherwise Known As Bat Wings.
    Trucks FOR DECADES Never Had Them.
    I've Driven Trucks With\Without And Noticed Insignificant Fuel Mileage Change.
    Bigger Nutserts Will Help.....for A While......until they too get "wobbly".
  5. p608
    2,181
    2,992
    Nov 10, 2016
    The problem is the material is too thin, nutcerts work good if installed in the proper material
  6. makterna
    86
    60
    Sep 14, 2021
    I think they worked well 690 000 miles ago when their holes were smaller. (Thats what he said)
  7. '88K100
    '88K100 Road Train Member
    1,402
    3,224
    Aug 23, 2020
    Nutzerts rattle out of the fibreglass. Its very common on the Freightliner the past 10 years
  8. SmallPackage
    5,666
    18,105
    Dec 20, 2019
    Marion Texas
    Only way to fix this is bolts through the hole with fender washers and lock nuts on the back side. (Inside the sleeper wall). Interior panels will have to be removed to do this.
