I can charging my iphone with the orginal charger i can plug in my ventilator in the cigarlighter everthing works nice,only the problem beginns when i like to charge my notebook ,is not charging correct is cuting the power,is the same when i start the engine,i was buying different powerinverter with 150v nothing is changing,i was buying new batteries(optima)for maybe 6 mounts,i have problems only with the notebook ,for 1 mounth i was buying a new battery for my notebook, somebody have a idea what is wrong,maybe is the notebook
Problem Charging my notebook with a 150 charger
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by gerardo1961, Jun 30, 2013.
Page 1 of 4
Your notebook may not like the "dirty" power that is being made by that cheap converter.
Are you having the same issues on household current? -
The problem is only in the truck,when i charge the notebook in the truckstop with normal power works fine
notebooks require pure sine wave, not "dirty power" from your 150 watt inverter. Also, cigeret lighter inverters dont do well on old trucks becuase the wireing wears and there wont be enough amperage to run it properly.
gerardo1961 Thanks this. -
What can i do nothing,maybe buy a new notebook with a better battery(less charging)
Try a larger converter that wires directly into the batteries. You need to look for something with a clean sine wave. I have no idea what brand that would be
I can understand an old truck having a worn out cigarette lighter plug that is difficult to get a good contact....but 'worn out wiring'?
Anyway, most of my electronic stuff charges OK with whatever the yellow cased inverter Pilot/FJ sells.
Power Drive, just looked at it.
Try reversing the polarity of the 115v plug from your notebook, if the plug will fit the other way.
Hard to believe, but a couple of the 115v things I have in the truck will only work when plugged in the right way. -
Make sure your inverter advertises "pure sine wave".
Or order one from here http://www.theinverterstore.com/pure-sine-inverters-off-grid.html -
PC chargers use a lot of power and a 150w inverter is no where near enough. Youd need a 750w or bigger.
I have a toshiba Satellite C655 notebook nothing special,years i dont have a problem only the last mounths
Page 1 of 4
