problem with 01 volvo with cummins N14 celect
Discussion in 'Volvo Forum' started by mark3219, Aug 1, 2013.
  1. mark3219
    mark3219 Bobtail Member
    12
    Hi this is my 1st post. I need some input on a situation I'm having. It started when I parked my truck for 2days for some home time. When I got to my truck it was dead. I checked to see if I left anything on and couldn't find anything. So I jumped it and made my delivery and checked my batteries which 1 was bad. But During the time I jumped it and made the delivery all of a sudden my speedometer with haywire and my truck shutdown on side of the road. I checked for any visual problems, checked solenoid, solenoid wire, wire harness etc. couldn't see anything. Truck started but this continues intermittently. My diagnostic is not working so I have no codes. I go to have it put on computer tomorrow but does anyone have any ideas. I've changed fuel filter, replaced battery, and checked all connections so far
  3. volvodriver01
    volvodriver01 Road Train Member
    Is it an auto or manuel?
  4. freightrunner
    freightrunner Heavy Load Member
    722
    182
    Mar 25, 2012
    Georgia
    Must be some wires touching.
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I have same truck, same engine & same problem as you. Mechanic found a wire that was touching the frame behind the sleeper.
    repaired the wire and have not had any issues since.
  6. mark3219
    12
    Thx for ur input...had it put on pc. It showed ground problem. Checked ecm ground fuse which was blown. All the faults couldve been caused by this. It also showed cam sensor. Replaced cam sensor. Replaced wire to selenoid. It still shutdown.Checked all wiring cant seem to find short. This is a real pain....Help!!!
  7. bravoo67
    bravoo67 Light Load Member
    252
    35
    Mar 15, 2012
    Brooklyn NY
    I had similar problem with my N14 same year lol .. In my case it was 5 AMP ground fuse right by ECM
  8. bravoo67
    252
    35
    Mar 15, 2012
    Brooklyn NY
    I would change ignition switch just in case
  9. Damage
    Damage Light Load Member
    67
    17
    Jan 13, 2012
    Newark, Nj
    Does this model have the fusible link in between the starter and frame? That can cause serious problems, but that is on volvo with volvo engine.
  10. mark3219
    12
    My ground fuse was also blown...That was the first thing I replaced...Now what???
  11. mark3219
    12
    Why the ignition switch??? are you saying that I could be turning truck on/off if ignition switch is worn out? I had a test light on solenoid when truck shut down. The ecm shuts off power to seleniod...Any other ideas??/
