Problem with courtesy lights
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dkig2001, Jan 27, 2011.
  1. dkig2001
    dkig2001 Bobtail Member
    9
    I have a 2006 volvo and a 04 trailer. When i turn on the courtesy lights, only the truck lights work. How would I turn on the trailer lights?
  3. NickB
    NickB Bobtail Member
    25
    4
    Jun 10, 2007
    Washington
    Did you bend out the prongs on the trailer side of pigtail yet?
    some of them have a split in the middle that a knife tip works well to spread--
    But be carefull not to spread em too far or they will snap...
  4. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Do you have one ore two trailer light cabels?
    Usually there are two 7 pin cabels. One is the main, other for additional lightling, reverce lamps and other..
    May be you have only main cabel.
    There is one other cabel - trailer ABS/EBS - used not only for TABS/TEBS power supply, but for trucktor-trailer brake system communication via CAN and you will see additional unit on CAN with dashboard - MID 137.
    It is not used for lightning but some drivers think they have pair of trailer cabels.
  5. The_Judge
    The_Judge Light Load Member
    257
    68
    May 25, 2008
    Montreal, Quebec
    From my own experience I found that replacing the plugs every few years is benefic for preventing theese kind of issues. What I hate the most is that electrical problems start in the winter times when is almost imposible to go under trailer and scratch in the dirt.
    I do have a Reitnouer 2007 trailer and the lights from the passanger side stopped working. Well I was lucky enough to be in California where the weather was kinda nice. Is very difficult for me to explain what I found in the back of the stop/position lights, in that "box" encapsulated. The dirt was 5 inch high and one of the plugs was disconected because of that.
    So better do the check-up for the electrical system before winter.
