Hello, I have a 2005 freightliner Columbia detriot 14.l 60 Sereris , so when ever I use my jake break AkA ( engine break) smoke comes out of the exhaust , not all the time but lot when it does . Does that mean my motor is burning oil , what's the cheap way to fix this problem. Thank you
Problem with detriot!!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by guru23231, Oct 7, 2013.
You don't have a problem, that is normal.
guru23231 and Criminey Jade Thank this. -
Does your jake work properly? You may need your jake rebuilt. Not a big deal.
guru23231 Thanks this. -
Yes it works really good , just lot of smoke out exhaust when I use it .
If it is due for a Tune up ,this is the time to do it ,cost a bout $500 & you need one every 50,000, I do it every 100,000guru23231 Thanks this.
It's a gray or a Little light blue smoke , but not a black smoke
As I said a that is normal, if you have a boost gage you will see it go up as you hit the Jake, boost = fuel, fuel = smoke. But as was also said if you have never had the overhead done it might be a good idea, and adjusting the Jake is part of it.
