Problem with kingpin or 5th wheel?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by D389, Apr 29, 2013.
  1. D389
    D389 Light Load Member
    99
    56
    Mar 24, 2013
    Texas Panhandle
    I pull an 53' Transcraft Eagle stepdeck and I noticed it started doing this about a month ago...
    This picture was taken when it had 500lbs on one side of the top deck, Ive seen it a lot worse.
    Its been to a couple shops and some say its the 5th wheel and some say its the kingpin, but when they inspect the pin they say its good. I pulled a brand new trailer while this one was in the shop for suspension work and the new trailer didn't do this. I'm convinced its in the trailer somewhere if the pin isn't the culprit. What do you think?
  3. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    Very interesting.... almost looks like a "high-hook" but obviously it's not if you unhook and rehook and it does the same thing. Have they checked the plate the kingpin is welded to? Maybe it is not flat or is warped??
  4. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Get on level ground. The 5th wheel only flexes so far.
  5. fortycalglock
    fortycalglock Road Train Member
    6,155
    6,584
    Jun 25, 2011
    Tourist Town, FL
    It looks like the plate and maybe some crossmembers are done for. I had a 98 Eagle the shop ended up calling the "rust bucket" after putting a KP, plate, and a lot of structural steel in above it.
  6. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    It sound's like the trailer has a problem. If you can pull another trailer with no gap, and a trailer with a gap, you found the issue. OF course, a straight edge would explain a lot if you put it on the apron of that Transcraft trailer.
  7. D389
    99
    56
    Mar 24, 2013
    Texas Panhandle
    It is, I'm parked on a concrete pad.
    What is the apron? Ill check these thing out in the morning.
  8. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    The Apron is the flat steel plate that surrounds the area around the Kingpin and what the Kingpin is attached to. It looks to me like the Apron is warped.
    It's definitely not the Fifth Wheel as that is as flat and straight as can be, so it's the trailer.
  9. Heavyd
    Heavyd Road Train Member
    7,780
    6,218
    Feb 4, 2009
    Yep, looks like the trailer got warped.
  10. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    something is bent... fifthwheel plate ore trailer frame...
  11. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    how old is the trailer? looks like the plate is shot and most likely the cross-members above it are broken / rusted out causing the plate to flex. when i did mine I replaced the 3/16 plate with 3/8 and new kingpin....should be an $800-$1000 dollar repair
