I'm on hometime, truck has been sitting in my drive since Thursday morning. I always start the truck up to air up the brakes on the afternoon before the day I'm due to go back out just so I don't disturb my neighbors too much in the morning.
On my display panel it said "Alert...No Data Entry"...there are no idiot lights that stay on.
RPM goes up and down, then stays down (restarted and it stayed up for a little longer). I depressed the throttle but the needle would not go up.
Oil pressure gauge won't come up (but there is oil along the length of the dipstick)
I drive an 06 Freightliner Century Classic.
Problem with my truck?
Discussion in 'Questions From New Drivers' started by musicgal, Dec 25, 2010.
on the truck(s) that i drove, there wasn't any idiot lights that came on either, but from your description, it does appear to sound like the same problems i had with the fuel pedal "black box".....(if i am wrong, sorry, i can only relate what i went through and your description)....
if it is YOUR truck, (as in you are an o/o).......if it is the fuel pedal, and if you do buy another one......might not be a bad idea to have a spare one with you for in the future this happens again.....and you're a million miles away from a repair shop or home......
look at the miles on your truck, all of ours went bad between 150,000 to 160,000 miles.....so every 150,000 miles, we were having problems all over again......
if yours is beyond those miles, (say you have right now, 300,000 miles) then figure when that same miles hits again, you might be replacing the fuel pedal/black box...(600,000 miles)....... -
Thanks, Rerun. I am a company driver.
Talked to Breakdown this morning and it appears to be an "under the dash cable problem" so I will be taking to truck to Freightliner tomorrow. -
That right there is your problem... There is no such truck.
There is a Century & there is a Classic... But no Century Classic -
You are right, Redd......actually it is a Century Class...I just went and looked at the thing on the side of the cab.
i once thought i drove a Mackinknew..... -
By the way....this part on my KW?
$425- nothing sold separately. Entire new assembly only.
..I opted to clean the crap out of it (spring/roller/ramp and connections)
instead of replacing it..... -
yeah we had all macks.....when it hit that mileage...??
they ALL needed a new fuel pedal....
i think a good cleaning might help, the connectors on the mack were nearly on the floor......and the roller was subjected to all kinds of crap. -
It was a pleasure to NOT have the accelerator return when it was supposed to.
