problem with naxa tv
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by david307, Feb 5, 2009.
  1. david307
    david307 Bobtail Member
    largo, fl
    I have a 13" Naxa NX524, if the truck is not running tv shuts down after a few minutes and will not work again until truck is running. Bought a Cobra 400 watt inverter, hoping to fix problem. It worked until Opti-Idle came on, it blew the fuse in dc plug everytime. Anyone else have this problem? Advice?
  3. Pur48Ted
    Pur48Ted Road Train Member
    3,643
    5,981
    Jun 14, 2006
    Grand Rapids, MI
    I am assuming the TV is a 12 volt?
    And the 400w inverter plugs in to a cig lighter?
    If YES to both questions, the answer is easy.
    1. If the TV shuts down when the truck is not running, it could be because the TV will shut-down IF the battery voltage drops below a certain point
    2. If your inverter blows the fuse when you start, it is for the same reason. Battery voltage drops while engine is off, then starting the truck causes a spike in the voltage at the plug.
    Try a larger inverter that connects directly to the batteries or use a larger fuse (double wattage) in the inverter plug.You might also check the truck's batteries and replace them if they are older than 1 year.
  4. david307
    largo, fl
    yes to both questions. batteries are new, just had a service and they were replaced. the tv is rated at 80 watts, cobra 400 watt converter is good up to 150 if plug into cig. lighter. I replaced fuse, a 15, with 30 and it has not blown yet. thanks for your reply, I appreciate the help.
  5. MrMustard
    MrMustard Road Train Member
    1,003
    529
    Dec 11, 2008
    Dayton, Ohio
    I bought that 400 watt Cobra inverter. That lighter plug cord with the fuse in it is pure garbage. The wires in it aren't thick enough to run anything more than a cell phone charger. I had a thicker cord from my old inverter and it works much better.
