Problem with power inverter
Discussion in 'Questions From New Drivers' started by Newdriver85, Sep 25, 2013.
  1. Newdriver85
    Newdriver85 Light Load Member
    59
    24
    Mar 22, 2013
    Philadelphia pa
    I recently bought a power inverter. I can't get it to turn on. It'll beep and that's it. I called the tech support line. They said it sounds like loss of power somewhere. It could be the wires or the fuse. I'm in a 2011 freightliner the wires were all ready ran. Anyone know where the fuse would be for the inverter? Hopefully it's something I could do. Thanks.
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Check where it is attached to the batteries. You might see a fuse there.
  4. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    The fuse would be on the unit itself or somewhere on the power line leading to it but if it is beeping when you try to turn it on then it clearly has power so a fuse would not be your issue.
    If you have anything plugged into it when you are trying to switch in on it may just be overloading it (drawing more power then it is rated for) and not allowing it to turn on. Unplug everything from if before switching it on and it it still fails it is probably new/defective product and you should exchange it.
  5. Truck609
    Truck609 Light Load Member
    238
    197
    Dec 17, 2011
    Arizona
    Unplug everything from it, turn it on......does it still beep? My guess, as stated above, you are overloaded.
  6. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Check and clean the connections to the batteries. You might be surprised how a dirty connection will come on, then cut it off when pulling more power. So many want to run the ground to the chassis, which will cause problems. The ground for inverters should be attached directly to the batteries.
    Also check the connections are tight, also at the invertor. Vibrations will loosen the connections.
  7. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    Or is this inverter powered by a cig lighter plug? Lots of missing info to diagnose the symptoms over the internet.
    Mikeeee
