Problem with the Volvo VNL 670 Transmission
Discussion in 'Volvo Forum' started by Gulsher, Nov 27, 2016.
  1. Gulsher
    Gulsher Light Load Member
    55
    9
    Nov 26, 2013
    Hello Everyone,
    we have a Volvo 2007 with the auto shift "meritor zf". It's giving me a very hard time. changed almost everything on it but still giving the same code. It works fine for some time and then just stuck. Turn off the engine wait for 30 min. then everything goes away. Doesn't show any codes. Took it to the dealer but they saying everything is fine. Just drive away and its starts again. Here is the codes its giving now
    mid 130 pid 43 fmi 2. Also shows code MID 144 PSID 205. Also it says "STARTING SWITCH STATUS ERRATIC" We changed the control module. Paid $5000. It seems it wasn't the problem. Changed all wires and censors. I don't know what else to do on it.
    Please advice if you dealt with this issue.
    Thank you
  3. Dave_in_AZ
    379,910
    I hope its not a bad ground. What were the symptoms leading up to the problem?
    Did it work fine, and then suddenly it did not?
    Where do you live?
  4. Gulsher
    55
    9
    Nov 26, 2013
    I'm here in NJ. It was fine. had this problem once or twice last year and gone. Had the clutch changed last year in Beaumont TX. All started like a month ago. You drive and it just go to neutral. The computer doesn't show the transmission. You turn it off and wait for 30 min. Turn on again and go. no faults.
    Maybe its some kind of electrical problem? Might be the ignition?
  5. Dave_in_AZ
    379,910
    I'd say it's either a sensor or a ground.
    Call the Volvo dealer here in Phoenix on Monday.
    Number 1 in the nation.
    They may be able to tell you where to look.
  6. Gulsher
    55
    9
    Nov 26, 2013
    OK. Thank you
    I will call them and let you know whats going on
  7. Gulsher
    55
    9
    Nov 26, 2013
    The proble
    The problem was with Voltage Doubler. cost about $1200. Runs smooth as of now. lets see what will happen on a road
    Dave_in_AZ Thanks this.
  8. Dave_in_AZ
    379,910
    Glad you got it resolved. Your symptoms sounded like erratic or disruptive voltage signal.
    It sucks you did not cross paths with a better shop / dealer to handle the issue. The certainly are not all created the same.
    There's only so much they can tell you on the phone. But the one here in Phoenix is simply outstanding. And I found the one near Lubbock, TX to be very good as well.
    Stay away from any of the " TEC EQUIPMENT " dealers.
    Gulsher Thanks this.
  9. Gulsher
    55
    9
    Nov 26, 2013
    I WILL KEEP IN MIND THOSE PLACES ALSO. We couldn't drive it anymore. Every 60 miles you had to wait for 30 min to cool it down and drive again. Those guys were helpful also. They called meritor and were on phone with them for 2 hours. Thanks again for you advice and help in this issue .
  10. Dave_in_AZ
    379,910
    Even a blind squirrel finds an acorn once in awhile ;).
    Snailexpress Thanks this.
  11. Yayo34
    Yayo34 Bobtail Member
    I have a 2007 volvo vnl670. It had a 10sp Rockwell manuel I changed it to a 13spd eaton. Now my speedometer and cruise do my work. The speed sensor is connected but it's not reading it. Any idea What can it be?
