Problem with Volvo battery protection system
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Karicz, Nov 13, 2010.
  1. Karicz
    Karicz Bobtail Member
    23
    Chicago
    I have problem with Volvo 670 2004. I driving and the Volvo battery protection system turn off everything in sleeper and cab. Battery is fully charged, gauge show me 13.9. Is same way turn off the protection system?
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    yeah, you can jump it. easily.
    KB3MMX Thanks this.
  4. Karicz
    23
    Chicago
    No, it happen with driving. After couple minut I hear the buzzer in my sleeper,after that is everything turned off.
  5. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    You want to have it checked and repaired if it is a rubbed threw wire or a bad conection even you could have a fire.
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Does LVD overide button help?
    first of all I check poor connection, corroded terminals and bad wiring. To jumo LVD relays is easy, but to find a problem....
    as I remember you can disable LVD (low voltage disconnect) with sleeper control panel, but not on all trucks.
    the easy way to disable LVD is find relay box in battery box and connect all thick positive wires together.
    KB3MMX Thanks this.
  7. Karicz
    23
    Chicago
    Do you now where is the LVD box in Volvo? I donot have LVD overdrive button. Anyway thanks.
  8. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    we operate European versions and boxes are usually in battery box, splitting positive wires. Seems to me they put all this ###t under the driver's side steps.
  9. jardel
    jardel Light Load Member
    110
    21
    Mar 8, 2009
    BUFORD,GA
    karicz i had the some proablem in the past is easy the red wire that go to the starter is lose some where check it from the battery to the starter mine was doing the some thing i have friend he had the some proablem in mine situation the screw at the starter where the red wire conect was lose.i hope that helps.
  10. wcboopster
    wcboopster Bobtail Member
    5
    i just got into one it is doing the same thing but my voltage is 13.7 running and 12.5 stopped our othe two charge at 14.1 and 12.9 stopped they both have the fridge running all night i cant even have my webasto run for 6 hrs without my fridge . my feeling is the voltage protection ecm is reading the voltage off the truck ecm and wondering if there is access if i was to get into the perimeters on the ecm or where the ecm gets its voltage info ie battery / starter ect .
