Problems w MP8 mDrive transmission 1st time owner
Discussion in 'Ask An Owner Operator' started by istrum, Nov 18, 2020.
  1. istrum
    istrum Bobtail Member
    44
    16
    Jan 24, 2018
    34953
    My equipment....
    2015 Mack chu613 Pinnacle
    MP8 mDrive
    Bought at 212 thousand miles (March 2020)
    Now at 279 thousand miles (Today, Nov 2020)
    The transmission problem is that it started to not have any power or engagement in the even numbered gears (2,4,6,8,10,12) ... rpms to 1000 but no power .... odd number gears working fine, but the mDrive still moves to the even gears and thus I get stuck with no power and forced to go to manual mode and still no power in the even gears.
    I brought it in for service and I am wondering about others with experience with the MP8 and mDrive from this year (2015) or other years. Has anyone had a rebuild? Or reman? done or installed? What was the cost? How much (hrs) labor? What was the parts cost? What's your story with either the cxu or chu models?
    Thanks.
  3. Ridgeline
    22,636
    120,580
    Rebuild with that amount of miles?
    no way.
    this sounds like a firmware issue.
    Have the dealer see if there is an update on the trans firmware.
    istrum Thanks this.
  4. DaytonTD
    DaytonTD Light Load Member
    164
    186
    Jul 14, 2019
    Edmonton, Alberta
    Unless you hear grinding or clunking it's probably an electrical or computer issue, possibly something physical like a solenoid. Doubt you need a new transmission with those low miles
  5. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    @istrum
    Couple of things Mack and Volvo share Engines and transmissions. So Mdrive is the same as Ishift transmission. Mp8 is a D13.
    Volvo has a 750k transmission warranty on the Ishift. I am not sure of Mdrive has the same warranty. Replacing the complete MDrive is pricey but at the mileage you are at it should be covered under warranty.
    Edit (MACK also covers Mdrice to 750k)
    Reason for edit: More information
    AModelCat Thanks this.
  6. AModelCat
    161,608
    Hopefully the time limits on the warranty haven't been exceeded yet.
  7. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    60months or 750k. He may get lucky.
  8. AModelCat
    161,608
    Even if its just off, might be able to get some goodwill out of them due to having such low mileage on it.
    Socal Xpress Thanks this.
  9. Gracefarms
    Gracefarms Bobtail Member
    Oct 6, 2022
    Did you ever find a fix having the same trouble
    pusherman Thanks this.
  10. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    I see all kinds of problems with isht tranys. last two stuck in gear wont start.
