Problems with a Detroit 12.7.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by WildHog, Jan 5, 2012.
  1. WildHog
    WildHog Light Load Member
    101
    22
    Oct 13, 2011
    AR
    2003 Freightliner 12.7 Series 60 Non Egr.
    The truck will just loose power at times usually going up through gears.
    When the power finally comes back (in a few seconds usually) then the truck doesn't come all the way back to idle quicly after letting off the excelerator. The truck motor hangs at about 1300 rpm or so blowing the gear change.
    It runs really good the rest of the time. 430/475 Any ideas?
  3. gravelhauler
    gravelhauler Medium Load Member
    630
    414
    Oct 20, 2011
    Lake Charles, La
    It may be suckin air.
  4. WildHog
    101
    22
    Oct 13, 2011
    AR
    Air sucking from leak in fuel line?
    I had a spot on the filter that looked like it was dripping from time to time but I took care of that.
    Any ideas where to start looking after that?
  5. gravelhauler
    630
    414
    Oct 20, 2011
    Lake Charles, La
    It'd be hard to say where to start. Could be a fuel line. Does it have a screw on type filter or a canister type?
  6. WildHog
    101
    22
    Oct 13, 2011
    AR
    Canister
    Fuel pro
  7. gravelhauler
    630
    414
    Oct 20, 2011
    Lake Charles, La
    It could be the canister. I've had that problem with one.
  8. snapon2
    snapon2 Bobtail Member
    42
    8
    Jan 13, 2011
    grande prairie alberta
    tps ..throttle position sensor..
    gravelhauler Thanks this.
  9. gravelhauler
    630
    414
    Oct 20, 2011
    Lake Charles, La
    Very possible. I didn't think of that. I was going on past problems with the fuel system.
  10. WildHog
    101
    22
    Oct 13, 2011
    AR
    I pulled the TPS out and on the bench it seemed to be fine. I was looking at it with a old analog vacuum tube VoltOhm Meter and it's as smooth as butter except at the very first part of the stroke where it snaps on like a switch and the comes to rest at about 700 ohms and then is smooth as butter up to about 2200 ohms, end of stroke. I have no idea what it's actually supposed to be? Maybe it should be 0-2200 ohms? I just figured it was working correctly but maybe it's not all there. Anyone ever test one of these TPS's on the bench?
  11. ptours93
    ptours93 Bobtail Member
    37
    4
    Sep 12, 2011
    orland park il
    it's measured in volts like 0-5 and it has to read a certain range.
