Problems with ThermoKing Legacy 650 APU
Discussion in 'Ask An Owner Operator' started by slow.rider, Mar 9, 2021.
  1. slow.rider
    slow.rider Road Train Member
    2,005
    4,741
    Apr 4, 2017
    NYC
    Bought a refurbished APU a couple years ago and apparently got a lemon. Trying to track down some strange electrical issues revolving around charging the batteries, and maybe it has some other problems as well but I just haven't gotten a good diagnosis yet. So here's the story.
    About a year ago it started tripping a relay in the glove box of my '13 Cascadia. The relay would first shut off, then repeatedly and rhythmically flip on and back off. It would do this at exact intervals for hours on end sometimes, but it would stop doing it just as randomly as it would start. Sometimes every night it would do it, sometimes it could go days without doing it. Sometimes it would only do it for ten minutes, other times all night. But it only does it when the APU is running.
    Now here's another quirkto keep in mind. Apparently this thing is supposed to just sit quietly and monitor battery level when it's on, and start itself up and charge the batteries when they get down to 12 volts. But mine won't do that. In order to get mine to charge the batteries, I have to set it to run the fan.
    Anyway, I've had it to a TK shop a couple times now and they say it should only need to charge the batteries once or twice per night. But mine needs to do so much more often than that. Unless the batteries are brand new, they'll only take enough charge to last maybe half an hour, and then it'll need to run for close to that to charge them back up, so basically it's running like 50% of the time to keep the batteries from dying.
    When it first started, I tried replacing all the relays but that didn't help. Recently I found out which relay it is. It controls the dome lights by the visors. If I turn one of them on while the relay is flipping, the light will flip on and off in unison with the relay.
    There's apparently some sort of short or draw or something that's killing the batteries prematurely. I replaced all four batteries on November 21, and had to replace them again yesterday.
    Maybe related, maybe not: in the past few months it would crank slower and slower when trying to start. A few weeks ago it started having a real tough time starting. It would crank real slow for like 20 seconds and give the low battery alert. But the truck would still start fine. Sometimes if I tried to start the APU over and over, after about 3 tries it would finally cough to life and then be fine for the rest of the night. But then a couple weeks ago I passed out with it running and then woke in the morning to discover it showing the low battery alert. It had failed to start overnight.
    That''s when I brought it to a TK shop. They said the starter tests OK but the truck's batteries are shot. I replaced the batteries yesterday and they lasted thru the night with no charging, then today they finally got down to 12v so I tried running the APU but it doesn't hardly do anything any more. The first time it just rebooted the control panel which shut off the fan, so it was on but not running anything. I tried it again, it cranked once reeeal slow and then rebooted the control panel again. The third time it cranked twice real slow and then gave the low battery alert. Again, the truck started just fine, so I'm running the truck to charge the batteries.
    Every shop I've brought it to can't find any problem. It rarely reproduces the problem at a shop so I have to explain it, and the most common answer I get is it shouldn't be possible for these things to be happening. I'm about ready to just have someone pull this thing off and install something new, but the only thing that stops me is the fact that it seems perfectly fine mechanically. It's just this odd electrical issue(s) apparently causing all the troubles.
    Any insight is appreciated. Thank you.
  3. Vampire
    Vampire Heavy Load Member
    772
    27,591
    May 14, 2011
    Transylvania
    If your comfortable with testing the unit yourself, I suggest you get a multimeter. I prefer a fluke meter.
    When the tripac unit is off, you are going to locate the mainboard/fuse box that is in the sleeper box. Open the box (should be a wiring diagram on the cover).
    Look for the little white block to the left of the fuses with the 6 ports. Locate the SCN which is the sensing line. Set your multi meter to voltage. Put the red test stick in the right middle port and stick the black test stick on something that is grounded (like the sleeper box door frame). You should read around 12.7 volts with the unit off. If it's reading 12.7 volts, that means your electrical connection to the batteries it should be good. If not, you might have a short somewhere.
    Also check all your fuses, that include the big fuse inside the apu engine cover. Make sure none of them are blown.
    You have to check all your wires. Could be the alternator. Disconnect the plug from the alternator and check the top contact (don't break anything). It should read around 12.7 volts. Don't forget to reconnect it after you are done.
    Also check to see if the inverter is running high voltage which will cook your batteries. The way you explained it, this might be the case.
    Good luck, let us know how it turns out.
    Dino soar, slow.rider and mitmaks Thank this.
  4. slow.rider
    2,005
    4,741
    Apr 4, 2017
    NYC
    Thanks for the info. Can you please expand on this passage a little bit? Are you talking my AC inverter? And would the high voltage be a setting or a defect. Ive never understood electricity real well. Anyway, thanks again.
  5. Vampire
    772
    27,591
    May 14, 2011
    Transylvania
    Yes. The AC power comes from the inverter. The high voltage would be an issue. Somewhere around 17 would indicate an issue. Get a buddy who is familiar with electricity.
    slow.rider Thanks this.
  6. slow.rider
    2,005
    4,741
    Apr 4, 2017
    NYC
    It has a readout, says between 12 and 12.7 most of the time. Not sure if that's just input and there's a different measure for output.
  7. Dave_in_AZ
    425,706
    Well it doesn't sound like it's your APU to me. Sounds like it's the truck.
    Could be a bad cab/chassis controller too.
    Other than that, I'd say you have a wire rubbing in a harness somewhere.
    86scotty, slow.rider and Vampire Thank this.
  8. slow.rider
    2,005
    4,741
    Apr 4, 2017
    NYC
    I guess I don't understand how that would make the APU unable to start, unless the wire with the problem is one of the ones that was installed with the APU. But my understanding is that the only connection between the APU wiring and the rest of the truck's wiring is via the APU's connection to the truck batteries. It's tough for me to imagine a truck problem that only manifests when the APU is on (or trying to be), but like I said, I never understood electric very well.
  9. 86scotty
    86scotty Road Train Member
    4,717
    12,954
    Aug 27, 2017
    Appalachia
    Good point. I'm thinking your ecu on the APU is dead. I can tell you this, though. You said yours is supposed to maintain battery charge when off but you have to set it to fan to get it to work. This is called standby mode and it's the same with my newer Tripac. You have to set the fan controller on the fan setting and then leave the actual fan adjustment knob OFF and it will then be on standby.
    So, mine has 3 knobs. Left one is AC, FAN, HEAT. Set it to the middle on fan and push center to turn on.
    Middle knob is temp setting. Doesn't matter where that one is for standby mode.
    Right knob is the fan adjustment knob. Leave it off.
    Mine will blink a minute and then show a little icon that says STBY on the left side.
    Hope that helps. I'd do this next. Pull your battery cover and unhook the cables going to the APU, it's about a pinkie size power and ground wire that run in a different direction than the rest of the wiring, pretty easy to spot. Carefully tape them and wrap them in something but leave both unhooked for a day or two and see if your truck is still losing power. That will tell you if the APU is causing the short/power loss.
    Vampire and slow.rider Thank this.
  10. reeferwrencher
    reeferwrencher Medium Load Member
    613
    1,577
    Aug 4, 2018
    That's quite the grocery list. Check if the alternator is charging and check the tripac battery terminals.
  11. 86scotty
    4,717
    12,954
    Aug 27, 2017
    Appalachia
    I just found this too. Shows how to turn the older TK's on standby mode, which they call 'null' mode?
