programing key fob
Discussion in 'Peterbilt Forum' started by chainslingr, Jul 4, 2015.
I think only a dealer can do that and it's expensive.
Its a gm remote. Most cars are a simple sequence of key on off lock unlock ect. I'd assume the truck is no
Did you ever figure it out ? Trying to do same on 2006 pete 379.
Try this:
1. Hold the key fob near the receiver. NOTE: The receiver is located behind the Speedometer/Tachometer cluster assembly.
2. Press and hold both the Lock and Unlock buttons at the same time for approximately 7 seconds.
3. When the key fob is resynchronized, the doors will lock then immediately unlock.
4. If the fob fails to synchronize, it could be programmed to a different truck or could have failed. -
Didnt work. Bought a new remote from amazon, a chevy remote. My old one I dropped it and it stoped working. Also tried the holding unlock while cycling key but nothing. Saw on YouTube a 08 pete the guy just connected a harness behinde glove box.earnies2 Thanks this.
Yeah pull the glove box and connect the 2 wires labeled rke. Hold both buttons on the the remote til the doors lock/ unlock. Donit again on as mamy remotes as you have. Disconnect the rke wires and it should be programmed. Procedure is the same for all conventionals. 389/388/367/386
579/567 has a wonky procedure to follow.
Also there is a fuse in the fuse box labeled rke as well for remote keyless entryWheeljack and spsauerland Thank this. -
Mine is an 06 379 pete couldn't find those rke harness, thinking its different on these models.
06 should have the new style dash with the wiper controls on the turn signal stalk. Open the glove box and dive in to the left. Might also need to pull the b panel and dive down. Wires are just kinda hanging out in there
Wheeljack Thanks this. -
Only found one gray
Only found one wire on my 06 peterbilt 379 labeled rke Input. Any help
