Propane torch
Discussion in 'Questions From New Drivers' started by wd40, Feb 2, 2014.
  1. wd40
    wd40 Light Load Member
    241
    116
    Nov 8, 2013
    Is it legal to carry a portable propane torch? If so, how do you secure it?
  3. rizob
    rizob Light Load Member
    199
    70
    May 16, 2010
    Mantua, NJ
    I carry them in my plumbing truck all the time. Along with 2 tanks of gas that are about 2' tall. If it's a small handheld one shouldn't be an issue at all. Just don't tell anyone when you go through a tunnel or no hazmat area. Hide it well. Border crossings might be a bit different. But campers have them and lots of people carry camping stoves so shouldn't be an issue. A driver that knows hazmat road rules will know better.
    wd40 Thanks this.
  4. Powder Joints
    7,932
    8,268
    Sep 25, 2007
    Rosamond, SoCal
    I carry one in my tool box, but I get the feeling you think it's a good idea as a self defense item.In which case bad idea. There is not a reason to have it in the drivers compartment going down the road.
    wd40 Thanks this.
  5. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    when i run to alaska in the early 70s canada was really hot about us trucks with aux propane heaters. or some hot to trot dot man writes you a ticket for propane in the cab of the truck. that being said i carried one in my tool box in the jump box for years without any trouble. have a safe trip
    wd40 Thanks this.
  6. wd40
    241
    116
    Nov 8, 2013
    Thanks.... Just a week ago before I finished CDL school, I saw someone use a hand held to thaw out ice in the area of the brake system near the tractor tandems... kind of a metal box the airlines were intersecting with.
    I coud hear air leaking out around the rear break chambers of the schools old backing lot tractor... It wouldn't hold brake pressure... The school has a Diesel shop. I asked them to check it out... Sure enough he heated that box up and the air leak stopped. Dude told me that is a good trick to know and the torches are cheap.
  7. wore out
    wore out Numbered Classic
    16,719
    204,531
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Just be careful with the thought to much heat is bad for rubber parts inside the valves. Also remember water always gathers in a low spot so look for a dip in the lines and try there. They also work if your brake shoes or drums were wet and froze together. I have never had any air line freezing trouble but being an O/O I get to say what is fixed so to speak. I won't put up with any air leaks, I want my truck to hold air all night, the more the compressor runs the more moisture it creates. I also change my drier filter regular. Of course pull my tank valves before I shut down every day.
    Naturally a company driver can't be so demanding, and it will depend on how the last guy took care of the air system. If water ever gets in the smaller lines for the air bags and such its hard to get out. Just thought I would pass on little ways to prevent using the torch. Just because I said I never had my lines freeze don't mean I don't have one in the side box just in case.
    They also make DOT certified push in connectors that self lock for plastic airlines. If you could get a couple of those to keep in the truck if you had a oops and got the torch too close with a pocket knife odds are you could be back on the road in a minute or less. No that I ever got the torch too close or anything when I was doing a road call.
    wd40 Thanks this.
  8. Voyager1968
    Voyager1968 Road Train Member
    2,378
    2,904
    Sep 11, 2008
    I currently haul spring water in a tanker trailer running local using a day cab tractor. We absolutely MUST carry a propane torch this time of year to thaw out the connections, valves, and vent. No place on our trucks to store it but inside the cab. So, for me anyway, there is certainly a valid reason to carry it in the cab.
    wd40 Thanks this.
  9. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    I carry two tourches and 6 bottles because 3come in a pack.
    Here is some advice never keep the bottle and torch screwd on together. I had mine leaking in my sleeper compartment. I smelled something strong I stopped shut the truck off and heard a leak took me a minute to realize what was going on.........p.s so glad I dont smoke
    LoboSolo and wd40 Thank this.
  10. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    A little off topic but along the same line. A small butane torch works good for soldering and shrink tubing electrical wiring. Butt connectors and scotchlock connectors are great for temporary repairs but need to solder and shrink tube the repairs
