Proper dock setup when driving a hostler unit?
Discussion in 'LTL and Local Delivery Trucking Forum' started by Shaner.STL, Dec 21, 2018.
  1. Shaner.STL
    Shaner.STL Light Load Member
    63
    26
    Jul 26, 2017
    Just looking for some advice from any or you who have hostled in the past as far as when you start your turns when docking pups and 53 footers at a dock. Do you start your turn right as you get to your spot, the spot before for pups and how many spots past your intended space when docking a 53 footer? Does the spot change if your approach is from the driver side or passenger side? I recently started hostling and my setups leave me with harder backs than needs to be. I've asked a few people about it and they just said that I will find my own way. It would help if I had a reference point to start the turns. There is just enough room on the dock to do a u turn with a pup and have pretty close to a straight back. Sometimes not if a 53' is sticking out next to your space you need to get into or not. When docking the 53' it would have to be done at most from a 45 degree angle. Thanks
  3. 25(2)+2
    18,758
    45,891
    Sep 18, 2006
    the road less travelled
  4. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,137
    Mar 9, 2014
    In a van down by the River.
    Im a hostler and I can help. I am at work right now. Give me a little bit to get back to you on this.
  5. Shaner.STL
    63
    26
    Jul 26, 2017
  6. FLHT
    FLHT Road Train Member
    1,424
    2,532
    Aug 2, 2014
    Make your turn so that the rear on your left side is even with left side of the empty hole. Straighten out and straight back.
    Shaner.STL Thanks this.
  7. CrappieJunkie
    3,996
    19,137
    Mar 9, 2014
    Are you driving an actual yard truck or a day cab?
  8. Shaner.STL
    63
    26
    Jul 26, 2017
    It's a yard truck. We do have day cabs that get used sometime but have not been in one yet. I could have to use one eventually so if you have knowledge on both I'll take it.
  9. Sho Nuff
    Sho Nuff Road Train Member
    1,175
    1,402
    Apr 9, 2015
    Setup for me personally isn't that important in a yard mule because of how easily the wheels turn. What is important to me is making sure your mirrors are correct, since everybody has their own preference of how the mirrors are adjusted...especially if you're sharing the yard truck.
    What I do sometimes to make things a little easier is to not lift the 5th wheel too high...but not so low either where the landing gear is dragging on the ground...but just enough so it looks more natural in the mirrors when backing up. Just the angle of the nose lifted higher than the tandem wheels can sometimes mess you up and can take some time to get use to. Constantly look at the angle of your trailer. Move you eyes back and forth from tandem to nose, and you'll know eventually if the angle of the trailer is correct over time...since all your doing is backing up trailers all day...lol.
    And one more thing...don't be embarrassed to go out and look...even in a yard truck. When in doubt...GOAL. It would be more embarrassing if you hit something because of pride or you couldn't spare a couple seconds to go out and look. In that case...it's better to use GOALS (Go Out And Look Stupid) instead :D
    Mike2633 Thanks this.
  10. Shaner.STL
    63
    26
    Jul 26, 2017
    Didn’t even think ab keeping the 5th wheel more level. Great pointer! I agree w GOALS vs hitting something haha. Thxs man!
    Mike2633 and Sho Nuff Thank this.
  11. CrappieJunkie
    3,996
    19,137
    Mar 9, 2014
    Sorry. Been busy. Holidays and all.
    I have to lift the trailer all thenway up cause we have hills to clear. So keep that in mind.
    As far as my approach, it really depends how much room you have. I dont have on set method per se cause our place varies widely. Some doors you have to blind side some you can take a lot of room and some you have to do a 90.
    If I have room in front of me I let my shoulder hit the middle of the space and do a left and then right. Remember it will be quicker cause you are not in a sleeper. Ill pull forward enough so I can see the hole and start backing then walk it in. Pull forward to correct if you have to.
    If you dont have a lot of room pull forward about 10 spots a head then start backing and put a turn it to bend the trailer and walk it in.
    Biggest thing is just practice. We have old trailers we dont use for anything, sometimes if we are slow I will practice backing that in to a door or spots on the lot.
    You will eventually get a feel for it. It took about 2 years to really get it to where it is just muscle memory.
