Proper way to measure flatbed wood floor?
Discussion in 'Flatbed Trucking Forum' started by istumped, Jul 5, 2019.
  1. istumped
    istumped Medium Load Member
    501
    240
    Feb 8, 2015
    Going to replace some wood flooring on a flatbed. What's the proper way?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    That strip looks rotted. Take it out.
    Find another strip as big and strong as the remaining strips on that deck. Chop to length, secure it (Nails or whatever it is...)
    Those deck planks come nice and big, and thick. If it is good quality you put on there in the hole it should last you a while.
  4. m16ty
    m16ty Road Train Member
    2,274
    4,963
    Jan 22, 2016
    I don’t know if I understand the question. I would think measuring would be self explanatory.
    As for how to fasten the floor down, I prefer bolts and clips. If you use self tapping screws ( like most trailers come with from the factory) you crossmembers can start to look like Swiss cheese after several replacements.
    Grubby Thanks this.
  5. istumped
    501
    240
    Feb 8, 2015
    So do you measure with the notch or minus the notch in the wood? Clear as mudd!!
  6. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    With tongue and groove you measure the flat part. Tongue doesn't count but groove does. When you put the boards in, cut the groove off so you're flat against metal and then cut the tongue off at the other end of the span.
    Sooo... measure your span, lay enough boards across to cover, lose 1 tongue and 1 groove.
    beastr123 and Grubby Thank this.
  7. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    Depends on what kinda cross members the trailer has on it. You cant always use bolts, sometimes you have to end up using the self tapping floor screws because the crossmember that the floor screws to is tubular and you cant get to the nut to tighten the bolt.
    Grubby Thanks this.
  8. Ruthless
    Ruthless Road Train Member
    9,092
    90,178
    Aug 28, 2010
    The City.
    Interesting, I never saw tubular crossmembers. Think that’d turn me off pretty quick if I did!
    When I had my rgn refloored, the crossmembers had some holes; I opted for spring washers and carriage bolts with lock nuts.
    The fellas that put it back together felt it was a lot of work lol
    Grubby and snowman_w900 Thank this.
  9. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    That's how my East is. The crossmembers are actual aluminum tubing as opposed to a H or I beam style crossmember.
    On a trailer like an RGN I'd say the carriage style bolts would be the way to go, but no doubt it would be work to do it.
    Grubby and Ruthless Thank this.
  10. Grubby
    Grubby Road Train Member
    2,475
    135,505
    Aug 30, 2016
    Fostoria Ohio
    Did ya tell him thats what hes gettin PAID for?
