Be glad when everyone learns it's a 9 speed not an 8. It just has 8 numbers on the shifter. But low counts. If you not sure look on the dash or close to it, there should be sticker with a shift pattern
Proper way to shift on a eaton fuller 8 speed
Discussion in 'Questions From New Drivers' started by Xzay, Aug 15, 2016.
Page 4 of 5
Ifin ya wanna spit hairs... do we count the 5 extra deep reduction gears? So its a 14 speed?
Blackshack46 Thanks this. -
Ten bucks and 15 thank you's, he didn't know about deep reduction!street beater Thanks this.
Depends. The main point I was making I'd there should be a information sticker for the transmission, if it hasn't been removed. As you can see this one doesn't have deep reduction. By adding.a splitter box it would be a 13. Only in special cases (8ll for ex) low can be split.
Have driven 8ll,9, 9 over (last 2 flipped) 13 over, 15 double over, 5x4 & Mack duplex
I ride a 15 speed giant mountain bike on the weekends.
Just put a milk crate on the rear to carry lunch for those long rides.Zeviander Thanks this. -
Oh i see the problem..... thats one of those defective trucks. I can tell by the pic.... says freightliner, trucks with those stickers are defective....Blackshack46 Thanks this.
Don't think about road speed. Go up and down the gears one at a time and you'll do fine. If you really want to worry about road speed, then all you'll need is the tire size, final drive ratio, differential ratio and the gear ratios of the transmission to calculate just what speed you need to be going to select the next gear.
You are overthinking it. It shouldn't be that complicated. -
If you really want to be picky so we count reverse as well, or are you limiting it to forward gears?
Page 4 of 5
