Proper way to shift on a eaton fuller 8 speed
Discussion in 'Questions From New Drivers' started by Xzay, Aug 15, 2016.
  1. Jubal3
    Jubal3 Heavy Load Member
    878
    950
    Apr 2, 2015
    Central WA
    On your test, you should be driving something you've at least got a passing familiarity with. Insist on an hour on the 8 speed before you test.
    What messed up organization is doing this to you?
  3. melsno
    melsno Light Load Member
    210
    109
    Dec 11, 2015
    I cant even double clutch to life my life i tried using the clutch to shift gears and i think i sent my lunch box out the window.
  4. Jubal3
    878
    950
    Apr 2, 2015
    Central WA
    I double clutch all the time when I'm empty, particularly in the first 6 gears. It's just smoother and easier on the transmission.
    Not to derail the topic, but when Eaton Fuller and all the rest want you to double clutch, it's probably not for nothing. I both double clutch and run the gears, depends on the situation. Either one takes about the same time if I'm trying to rush it. When I run 'em, which is most of the time, it's sheer laziness.
