Proposed maintenance cycle for Cascadia w/ DD16 questions
Discussion in 'Ask An Owner Operator' started by Gaius Romulus Rex, Oct 22, 2025.
  1. Gaius Romulus Rex
    Gaius Romulus Rex Bobtail Member
    17
    Apr 26, 2024
    So a few associates of mine and I are thinking about starting a fleet, and I'm working on developing a PM schedule for the trucks. They're going to be Cascadias with 600 horse DD16s, and I'm trying to set this up to minimize downtime. I'm thinking that we'd service the bottom end, reseal, and inspect the water pump around 450,000 miles. Bottom end service would entail replacing the oil pump, suction manifold o-rings, oil pan gasket, and inspecting the oil pan for wear, cracks, and corrosion. Given the proximity of the oil cooler to the water pump, I'm thinking that we'd replace both at the same time. Belts and tensioner would be replaced every third or fourth oil change. The EGR cooler and valve may be replaced at the same time as the turbo and actuator, I'm not sure yet. Every 800,000 to 1,000,000 miles we'd do a full in-frame, if we don't replace the trucks before then. Every coolant hose would be replaced every 120,000 miles or annually, whichever comes first.
    What do you guys think about this? Is this overly aggressive for service? Or is this the kind of maintenance profile that a new fleet would need to succeed in this market? We're looking at hauling dry van, currently contracted pet products with a mix of LTL freight from WestRock, Sofidel, and USPS contracters
  3. Ridgeline
    22,597
    119,926
    Very few fleet owners use an amortized replacement/maintenance schedule. They have deep pockets and work the fleet with the goal of low downtime/repairs to service their customers.
    I use the amortized system, but I won't offer a look into how it is structured or where to find the data; however, every component has a specific MTBF rating as new OEM parts. For example, I would not replace hoses at that low of mileage; they have an MTBF of around 600,000 - OEM parts. My records seem to point that there is a failure around 750,000 miles.
    New fleets should just stick to factory schedules until established.
    You also need to learn how to use the tools needed to establish baselines and track the needs of the truck/engine.
    There is also a need to make sure the driver INSPECTS the truck every day and does so properly. I have some issues with drivers not doing this, but that's up to you to find good drivers, which is #### near impossible. One reason why I have a pretrip for a pre-employment test is to see if they know anything about the truck. Just because you are accident-free doesn't mean you are smart enough to check the oil properly.
  4. Sons Hero
    Sons Hero Road Train Member
    2,709
    27,348
    Jan 8, 2021
    Indiana
    I didn’t even know the DD16 was an option for a Cascadia? As Cascadias, don’t expect them to hit 1,000,000 miles. Very few do.
  5. snowwy
    snowwy Road Train Member
    20,587
    13,307
    Jul 6, 2009
    DD16 came out at least 10 years ago.
    Gridaxe5588 Thanks this.
  6. Long FLD
    Long FLD Road Train Member
    12,438
    51,572
    Mar 4, 2015
    If you and your associates want way less headaches just get on a 3 year trade cycle and don’t try and run emission trucks to a million plus. Let everything be someone else’s problem after you trade out in 3 years.
  7. Sons Hero
    2,709
    27,348
    Jan 8, 2021
    Indiana
    I know full well when the DD 16 came out, I just didn’t know it was an option in a Cascadia. Seems kind of pointless to have a big engine, in a truck engine engineered for fuel economy
    KDHCryo Thanks this.
  8. KDHCryo
    KDHCryo Medium Load Member
    552
    798
    Sep 14, 2023
    There is absolutely no reason to run a DD16 @600HP for that kind of freight.
    A DD13 at 400 or even 450HP max would save thousands per month in fuel, per truck.
    You are way out of your lane if you are the one specc'ing trucks for this start up operation, no offense meant.
    Detroit's have had a plastic oilpan since 1987 with the Series60, no need to inspect for corrosion.
  9. Big Road Skateboard
    6,627
    37,152
    May 2, 2021
    I would agree, and the maintenance schedule the OP posted is absurd.
    Sons Hero and Diesel Dave Thank this.
  10. KDHCryo
    552
    798
    Sep 14, 2023
    1. Yep, all Mega's do that. OEM oil changes at every 125K miles, never change the transmission, pumpkin or bearing oils, trade it in at 350K miles.
    2. Basically you get a truck that runs 3 years for 125K miles a year with minimal downtime for $25k per year in payments, and get to write off depreciation.
    Siinman Thanks this.
  11. Trucker61016
    Trucker61016 Road Train Member
    1,366
    4,105
    Sep 18, 2017
    Linville, Va
    It's not the DD15 IS FUEL ECONOMY, THE DD16 is for raw power and heavy haul ......
