Proprietary software???
Discussion in 'Trucks [ Eighteen Wheelers ]' started by GCDMN., Jan 7, 2016.
  1. GCDMN.
    GCDMN. Light Load Member
    216
    46
    Oct 15, 2014
    Minnesota
    My work bought two used 2012 International Pro Star+'s that had gone through the Int. Diamond Renewal program. Owner got them mainly cuz of a 200k engine warranty. One day cab, one sleeper both 250 thousand miles. The sleeper truck has been a problem since pretty much day one. Constant regen, 6 times in the first 1500 miles and been getting worse no matter what the service shop says they have done. Not using this to rag on International, i really like the day cab and since its been going on since early in the ownership the dealer is working with us for the most part. When you have a bad truck it's never enough though. One of the things in all this we find out International has proprietary software on the Maxxforce engines so only a International shop can work on them. How common is this for truck manufacturers these days? Wondering this because it sure seems like we are heading down the replacement road already and I hear so much grumbling about all newer low emission trucks no matter the brand. Prior to these trucks our newest was a 2008.
  3. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    It is very common for manufactures to do this. The good thing is that 2013 and newer trucks must be OBDII compliant which means generic code readers will be able to (if they are programmed for it) read the codes on the truck. Similar to scan tools used in the automotive industry.
    NavigatorWife Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,805
    6,255
    Feb 4, 2009
    "ServiceMaxx" is the program used to communicate with them. There are customer versions you can purchase. You don't have to go to a dealer.
