Pros and cons for spread axle vs tandem on end dump
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by iamfargo, Apr 10, 2019.
  1. iamfargo
    iamfargo Light Load Member
    107
    22
    Feb 20, 2019
    me and a buddy was having a discussion what’s the pros and cons for spread axles on a 40 ft end dump vs tandem ?? If you can only haul 80k why is a spread axle needed ? Please elaborate thanks !!
  3. Majestic 670
    Majestic 670 Heavy Load Member
    908
    809
    May 10, 2016
    Landcruiser
    part of him likes buying tires
  4. iamfargo
    107
    22
    Feb 20, 2019
    So what do you prefer ?
  5. Zeviander
    Zeviander Road Train Member
    4,887
    36,995
    Jan 23, 2015
    Winnipeg, MB, CA
    Well, the spread gives you 40,000 lbs on the rear of the trailer. Depending on the product, you have more flexibility to pile it up back there I guess. Also, the front axle will pull some weight off the drives, so if it's a heavy tractor, that would be a small plus.
    Shecky and Tombstone69 Thank this.
  6. Tombstone69
    Tombstone69 Road Train Member
    1,010
    1,346
    Dec 20, 2018
    Jersey shore
    What Zeviander said, also if you put an air lift on each axle,you can save wear on tires by running on a single axle when empty and shortening your turning radius(just watch the swing), it also gives you more stability when dumping(unless it's a frameless).
