searched for an answer but couldn't find a definite.
Can anybody tell me what size bedding would be used on a 2016 prostar? I'd measure but it's in bay 47.
Thanks
Prostar bunk size
Discussion in 'Prime' started by Robd1178, Feb 15, 2016.
I use a full size fitted sheet set, fits good and never comes off at the corners
Robd1178 Thanks this. -
Thank you!
The ProStar I had was about 6 inches longer and 3 to 4 inches wider than a twin mattress.
So the full size bedding worked out great...a little extra to tuck under.
The factory mattress in them are not the greatest.
I picked up a Sealy memory foam topper from Walmart and what a HUGE difference..It was the 4 inch thick dense foam that has the cover with a zipper on it. -
Twin mattress
Yes they are called twin xl
darthanubis Thanks this. -
It's a long twin. You might have to search a lil, I'm sure bed bath and beyond has long twin sheets.
Got mine from Walmart
