Prostar maforce
Discussion in 'Ask An Owner Operator' started by 77fib77, Apr 30, 2016.
  1. 77fib77
    77fib77 Road Train Member
    11,401
    74,366
    Jul 7, 2010
    St Louis
    mxpx148 and wstar2003 Thank this.
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,119
    May 19, 2011
    Offer $10,000 and pull the boat anchor out and put a decent engine in it.
  4. Thermos Bottle
    Thermos Bottle Light Load Member
    281
    16,713
    Apr 6, 2015
    GA
    Lol, I'm driving one now. I have a break down about once every 2 months. The engine also has poor power, so it won't pull well when loaded. Lots of cruising in 9th gear. The listing says 475hp, but mine's more like 360.
    freightwipper Thanks this.
  5. AModelCat
    161,783
    A hamster running in a wheel is on about the same level as a MaxFart.
  6. DUNE-T
    DUNE-T Road Train Member
    7,021
    17,080
    May 10, 2015
    Detroit, MI
    What about if emission stuff is removed, is this engine OK otherwise?
  7. realdesertkickin
    realdesertkickin Heavy Load Member
    925
    753
    Nov 18, 2013
    Tustoned Arizona
    I been in a lot of 2012 2013 maxxforces...all have too small of passages in the emissions area....they clog up around 100k, check engine light comes on, power goes bye bye...
    By 250k, the turbos go...very cheap motors made to emit clean clear air for exaust...stoopid
    You can unhook the sensor wire where driveshaft comes out of tranny(loop it with a paperclip)...I had daycabs, so I could get to it easy when fuelin..It'll cut off all the governors...bypasses the emissions controls, rpm's, mph's..It'll get ya up the hills then..
    It will completely make the dash go bannans for awhile..I downloaded "digihud" on the smartphone to use for speedo..
    The other negative, it takes out odometer, which is where most men would get in trouble...I did it on fridays...lol
  8. fortycalglock
    fortycalglock Road Train Member
    6,160
    6,602
    Jun 25, 2011
    Tourist Town, FL
    30k is way too much, they are actually selling in the teens. I'm with Oscar, 10k and put a different engine in. If it were legal or if I needed a farm truck, I'd put a series 60 Detroit in.
  9. bzinger
    bzinger Road Train Member
    16,635
    66,094
    Dec 10, 2014
    omaha , ne
    I ran a 2012 prostar last summer with a 430 maxxfarse in it ...liked the truck but the engine was an underpowered , oil guzzleing POS that lived in the shop , around 380k it lost all oil pressure and the dealer cobbled it back together to get it home and ran even worse , boss traded it off cause he found a dealer dumb enough to give him 40k for it ...that was last June and it's still sitting there .
  10. Pete jockey
    Pete jockey Medium Load Member
    502
    518
    Feb 28, 2015
    North of Pittsburgh Pa
    Those seem to be the general consensus on max force engine...underpowered and loves being in the shop
    mjd4277 and bzinger Thank this.
  11. 77fib77
    11,401
    74,366
    Jul 7, 2010
    St Louis
    I'm passively looking for a new truck. Mine is fine, but the 48" flat top is too small.
    I don't dare buy a max force engine.
