Prostar self-sealing air leak?
Discussion in 'International Forum' started by double yellow, Jun 5, 2013.
  1. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    I've got this air leak in my 2011 Prostar that I just can't track down. For weeks I've been spraying every connection looking for bubbles and even had a shop try their luck. It is a slow leak (1psi drop every 4 minutes) -- I only notice because I'll come back after 2 hours and it'll be at 95psi instead of 125. At first I dismissed it on wind shaking the truck/trailer, but it does it every time & started maybe a month ago.
    Once it hits 90psi, the leak almost goes away. It'll have to be parked over 12 hours before the tractor protection valve pops (55psi).
    Any ideas?
  3. Big_jon
    Big_jon Light Load Member
    139
    60
    Apr 12, 2013
    Doubt you will find a 1 psi leak every four minutes. Probably coming out of a brake chamber though. DOT allows 3 psi per minute anyway. My truck completely airs down in 30 minutes. Your good to go.
  4. A21CAV
    A21CAV Road Train Member
    1,848
    2,156
    Oct 4, 2011
    Laredo, TX
    Prostars have a common leak behind the air filter housing at one of the hard plastic lines. You need to remove the filter housing to get to it.
  5. Heavyd
    Heavyd Road Train Member
    7,752
    6,186
    Feb 4, 2009
    Check your seats and see if they have the optional "back cycle" button feature. This is the back massage function in the seat. It is air powered and will continue to cycle regardless of key state and cause the air to drain down.
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    ouh, I'd check air driyer purge valve and modulators exaust....
