Prostar speaker replacement
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by mxpx148, May 4, 2016.
  1. mxpx148
    mxpx148 Road Train Member
    1,232
    759
    Oct 2, 2013
    NEPA, PA
    Can anyone tell me how to get to the speakers in the sleeper on a Prostar? It looks like the whole rear panel would have to come off...say it ain't so :p? Also, can anyone point me in the right direction of removing the door panels to get to the fronts?
  3. goliatcastro
    goliatcastro Bobtail Member
    Let me know when you find out
  4. RedRyder66
    RedRyder66 Bobtail Member
    Sep 19, 2018
    There are 5 tabs on the metal grill. 1 on top 2 on the sides and 2 on the bottom. You need to pry gently on t the top and sides. The top tabs are approx 1 inch in from the corner at the 90° corner NOT THE ANGLE CORNER. Once you get the top a little loose you can pull the top and sides out and roll the grill towards the bunk to release the bottom 2. Reshape and reinstall bottom 1st the align the sides while pushing in then the top.
    mxpx148 Thanks this.
  5. djdado
    djdado Bobtail Member
    13
    May 7, 2014
    Here it is 2018 pro star rear speakers access.. easy and slow play with grill to get it out.
    These are 6.5 inches speakers and they are junk
