Protecting a 1/4" air line under the cab
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hanadarko, Jul 21, 2012.
  1. Hanadarko
    Hanadarko Independent Owner/Operator
    2,970
    934
    Oct 1, 2009
    Midwest
    I have to run an 1/4" air line and need to go above and near the exhaust pipe...about 5" clearance at best.
    What can I run the air line inside of, or wrap it with to protect it from any heat damage?
    My kid has a Ford SUV and they ran the spark plug wires inside this asbestos looking sheathing and that was one idea I had as a possibility.
    Anyone have any other thoughts? - I cannot relocate the air line....
    Thanks,
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    what is the airline for?
    Is it possible to tap into a line somewhere else and come from a different direction?
  4. nicholas_jordan
    nicholas_jordan Medium Load Member
    608
    101
    Mar 31, 2012
    temple texas
    I am going to go with "go to an auto-salvage yard and ask for asbestos looking sheathing that goes around some exhaust manifold" as well as re-route & stand-offs
  5. bender
    bender Road Train Member
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    If you insulate the line for the purpose of protecting it that may cause the line to hold heat and cause failure. You could fabricate a sheet metal heat shield and hose clamp it to the exhaust pipe at that point or you could use a stainless braided air compressor hose in that section above the pipe, it is made to take the heat or a hard line in that section would work too. Leaving the line unsheathed will aid in keeping it cool. The heat shield on the exhaust pipe would really help dissipate heat when truck is not moving.
    Hanadarko Thanks this.
  6. Hanadarko
    2,970
    934
    Oct 1, 2009
    Midwest
    Good information...
    What I did for now, is use split-loom plastic standard wire loom and tied it off away the best I could.
    I am going to watch it and see if the plastic loom starts to melt in any way.
    I used hot water heater split foam insulation on the AC lines that run even closer to the exhaust pipe and the foam isnt even melted.
    That stuff melts if you look at it the wrong way!
    :biggrin_2554:
  7. bender
    2,105
    1,360
    Jul 20, 2010
    Don't Kid Yourself
    You may have no trouble with it at all with a free flowing exhaust. It's the ones that are all choked down with allot of back pressure that build so much heat in the pipes then radiating it everywhere.
  8. Taildragon
    Taildragon Heavy Load Member
    723
    449
    Jun 22, 2012
    Indiana
    Bender is right on, in the old days we used DOT copper tubing for the air lines as well as wire brade hose. The trailer dealerships for the most part still stock the DOT copper line, and "no", you don't want to consider standard water line copper tubing, it is more brittle and has a thinner wall thickness, it will not stand the vibration. You will still be able to use the same DOT brass fittings with the copper tubing, just remove the shiny stainlees steel insert that goes up inside the nylon line to keep it from collapsing, it won't work with the copper, and the copper won't cpllapse as bad as the nylon, just take a pair of plyers and grasp the stainless insert, and it will com right out of the fitting. Just use the copper in the area near the exhaust line, use nylon everywhere else.
    bender Thanks this.
  9. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    They make high temp split loom fwiw. Personally I would take some half inch airline split it down the length, and zip tie it in plac over the 1/4 in stuff. You could also do a heat shield preferably attached to the heat source with an air gap. Or wrap with turbo tape.
  10. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,046
    May 13, 2011
    Middle Tennessee
    Aluminum foil.
    If it's really important line I would use a tube over the exhaust.
  11. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    You can get the spark plug heatsheilds at napa I use them anytime I work on a cummins ism egr motor for the water temp harness.just use the plastic split loom cover and run the line with all the factory lines and up with the airlines that go to the cab air ride of airlines directly under the cab
