PSA: Overtorque bad Steer lug-nuts spinning with stud. Unable to remove wheel.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by blanco, Jan 6, 2015.
  1. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Driver had an independent shop install 2 steers about 6 months ago. He decides to get Michelin XZA3 and move his steers to trailer.
    3 lug nuts kept spinning. :biggrin_25510: and spining. Tech comes back and is like hey we got a problem. Sure enough, it was overtorqued and after marking them, showed it to the owner. He mentioned that when they installed the steers at a "major" tire shop, when he left it was making a scraping noise from front. The same side where the lug nuts are frozen to stud. Whut!!!
    He is taking it back to "major" tire guys. I told him he might have to cough up a new hub + labor. He will call me back.
    10, 2 and 1 were frozen on. Yikes.
    http://i.imgur.com/87LYtCy.jpg
  3. blanco
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
  4. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    It happens. Get a cut off wheel cut the studs, replace them, move on.
  5. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    Seen numerous times tire guys install wheels with 1" monster impact guns. These guns can go well over 800 ftlbs so they are obviously over torqued. Just lazy workmanship.
  6. blanco
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Wish it was this easy. Guy will probably need a new hub as the studs have ridges on the hub that keep them from moving. 3 Studs. Ouch!
  7. blanco
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Yes sir. I saw a roadside guy wail on the first stud with all his might to "seat" it. Danmit Son.
  8. rollin coal
    rollin coal Road Train Member
    13,440
    27,392
    Mar 29, 2008
    TN
    First time I ever put my own wheels on I was amazed at just how little you actually have to impact. Of course I seat the wheel, clean and oil the threads, run all 10 lugs up as tight as possible by hand. About 2 seconds or so on the impact then you've got a half turn to 450 ft lbs on the torque wrench. Every time. Drive it a mile or two and re-torque - never once have any of them ever needed a retourque. If everything is clean and seated well it shouldn't. Thought back to all the times I had seen people in shops seating a wheel that was tilted at a bad angle and after the lug was tight still just hammer away. You don't have to do that.
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I have couple of lugs inside cabin to replace if I see thread is worn.
    yep, I had to cut lugs too!!!
