PTO Explained - New Parts Guy
Discussion in 'Trucks [ Eighteen Wheelers ]' started by PeterbiltParts, Oct 2, 2023.
  1. PeterbiltParts
    PeterbiltParts Bobtail Member
    Hello,
    I am a new parts guy for a Peterbilt mechanic with no experience. I've been at the job for 6 months and am starting to get the swing of things but I don't have anyone to ask specific questions about how the parts work and what they do.
    Can someone explain to me as much as they can about the PTO?
    Thanks,
  3. TNSquire
    TNSquire Medium Load Member
    571
    1,967
    Oct 13, 2016
    Decatur, TN
    PTO is power take off.
    It’s used to drive accessories like compressors, pumps, and blowers.
    Depending on the accessory, the pto must spin at a specific rate to drive it effectively and efficiently.
    As an example, i can unload 50,000 pounds of plastic pellets in 50 minutes with truck a that’s optimized, but the same load with truck b takes an hour and a half to offload because it don’t spin up enough to build pressure the way it needs to in the trailer to push the product volume.
    The pto is connected to the transmission, and there’s a switch in the cab used to engage or disengage it.
    Never drive with the pto engaged though.
    Engage the pto at low rpms, then spin it up to running speed.
    When disengaging, reduce rpms to idle, then disengage it.
    Grease your driveshaft to the pto accessory often.
    What else would you like to know?
    prostartom and PeterbiltParts Thank this.
  4. 201
    201 Road Train Member
    13,048
    26,965
    Apr 16, 2014
    high plains colorado
    Can't add much ^, except, a power take off is universal in the industry, usually made by an outside company, not Peterbilt. All truck transmissions have an access hole to mount one, and usually a driveshaft powering the pump or compressor. PTOs can have different gear ratios, to spin whatever fast or slow, depending on the product. Most modern PTOs are air engaged, but many older trucks, like dump trucks, have a manual engagement with a lever.
    All hail the PTO,,,it saves a lot of shoveling!:biggrin_25514:
    prostartom, TNSquire and Sons Hero Thank this.
