pulled inspection plate off to grease throw out - this fell out
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollin coal, Jul 23, 2016.
  1. rollin coal
    rollin coal Road Train Member
    13,267
    26,722
    Mar 29, 2008
    TN
    Like the title says see the pic below. Anyone know what it might be? I felt around in the bottom of the housing and there was nothing else down there. Looks like some kind of elongated narrow half moon key shows signs of heat and bent up on the one end. Clutch engages and disengage just fine. I did notice last week sometimes when I depress it felt like it would catch, i'd have to wiggle the pedal to get it to depress any further. But other than that it seems normal. I wonder what's in my future?
  3. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    I'm going to take a stab in the dark guess that's it is maybe an edge off the spline shaft. I wouldn't worry about it if it's working fine though.
  4. Taildragon
    Taildragon Heavy Load Member
    723
    449
    Jun 22, 2012
    Indiana
    Throwout bearing seal or ball retainer? Have you noticed any difference in sound when your foot is on the clutch? Let us know when you find out...
  5. rollin coal
    13,267
    26,722
    Mar 29, 2008
    TN
    It's really not making any noise or acting differently. But when you see a piece of metal fall out of something it makes you wonder.
    tommymonza Thanks this.
  6. rollin coal
    13,267
    26,722
    Mar 29, 2008
    TN
    I will add that my clutch brake has always been flakey since the clutch was installed about 6 years ago. It barely has any at all and has always been like that. I have to go thru some special maneuvers at times to get it into low without grinding. Sometimes there's no time for that and I just put it in gear. Might be from the occasional grinding. I hate doing that but sometimes it can't be avoided.
  7. Taildragon
    723
    449
    Jun 22, 2012
    Indiana
    With no difference in sound, my next guess would be a portion of one of the clutch discs has come apart, could be a piece of steel between the fibers that broke off, maybe getting stuck in the process until it spun free... I would just keep running it and check it again in a few days and see if any more debree has come loose... Hang in there...
  8. jamespmack
    215,554
    Piece of clutch disc. Clutch job in near future.
  9. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    seeing some of the clutches we removed,and how utterly beat up they were,yet working just fine...i wouldn't waste 2 seconds worrying about that piece after looking for and finding no obvious damages.
    tucker Thanks this.
  10. jamespmack
    215,554
    Oh i not saying pull it. But do it before it scatters. Normally when you have engagement problems, or dampner spring broken and laying in bottom. But for me if its a fleet truck i pull them at first sight of problems. My way of controlling down time. Now with my own truck. I might worry my butt off and run it a bit. But id rather pull it early with scheduled down time versus unplanned down time. If you have never seen a 15.5 clutch scatter, you dont wanna. Ive replaced customers flywheel, flywheel housings, starters, trans input shaft, clutch housing, wiring harness. Floor pans, and one time it took out trans case. Did one that ended 18k to put it together. So on my truck. I have no problem throwing away a half used clutch.
    Big_D409 and Dave_in_AZ Thank this.
  11. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    I had a spring come out of the clutch disk one time. It had some spare parts that looked like that. It looks like part of the retainer the holds the springs in. The pedal would not depress like you say.
    I almost ran a ground guide over that was not paying attention. I was backing slowly down hill and had to blip the throttle and jerk it out of gear. I sat there and played with the clutch pedal for awhile and was able to get it working long enough to get it to the shop. The shop had a big pile just like it said it was an Eaton issue. They installed a Lipe disk and an easy pedal Eaton pressure plate.
    Mudguppy Thanks this.
