Puller/pusher
Discussion in 'Heavy Haul Trucking Forum' started by me myself and I, Sep 25, 2017.
  1. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    So ive seen this puller/pusher combo other day, and it got me wondering.
    Are both trucks brake systems connected to the trailer. And do the drivers just talk on cb, or are the trucks connected some way.
    And on such a big jobs do they have a mechanic/tire changer go along.
  3. Landincoldfire
    Landincoldfire Heavy Load Member
    909
    4,976
    Sep 27, 2015
    New Holland, Pa
    Brakes work off the truck air system.
    Big moves require a maintenance truck and sometimes even a bucket truck.
    We use both CB and private band radio.
    not4hire and Oxbow Thank this.
  4. m16ty
    m16ty Road Train Member
    2,274
    4,963
    Jan 22, 2016
    Most of what I've been involved in, the main truck controlled the trailer brakes. Yes, they talk on the CB a lot to know what to do. A good pusher driver can pretty much tell what to do without the main driver communicating verbally with him.
    I did see a Perkins setup the other day and there were air lines coming from the front of the pusher truck to the trailer. I wonder if the main front truck controls the front axle group and the rear truck controls the rear axle group on that setup? Or it could have just been for more air supply and the front truck still controlled brake application.
    Some trailers, as in long line Goldhofers, need to have a pony motor supplying on-board air to have enough air supply for all the axles.
    not4hire Thanks this.
  5. me myself and I
    735
    312
    Oct 5, 2009
    vernon hills,Il
    On that load that ive seen puller had set of glad handles on front bumber. That what got me wandering.
  6. Heavy Hammer
    Heavy Hammer Road Train Member
    1,184
    5,890
    May 1, 2013
    In purgatory
    The only time I've seen an air connection from the push truck it was the emergency/red line only for increased supply capacity. The service/blue line was blocked with a dead plugged glad hand. The electrical is connected because the push truck is the rearmost lighting, so lights, brakes, & signals are controlled from the main truck as any trailer combo would.
