There's a pully bearing that's been chirping for about a week or so. None of the bearings are loose to the hand wiggle test.
Any help in identifying which one it is or eliminating which one its not, would be a huge help. Thanks in advance.
Pully barring
Discussion in 'Ask An Owner Operator' started by feldsforever, Jan 10, 2021.
Most likely your idler pulley and it is an easy replacement on most engines.
feldsforever Thanks this. -
Thank you
Take a spray bottle of water, squirt water on each pulley hub in turn, when the noise stops briefly you have found your culprit.
Usually idler, as ridgeline said.
Tensioner is also a likely suspect.GoneButNotForgotten, JolliRoger and feldsforever Thank this. -
Hmm I have plenty of water thank you.
A 3' rubber hose. One end to your ear the other by each pulley. This helps isolate the source.
Same as above.feldsforever and Hammer166 Thank this. -
feldsforever, Cattleman84 and xsetra Thank this.
Some noise you can start hearing midair with a hose.
Staff or rod works great pushed against the hard block or valve cover, trans case.feldsforever Thanks this. -
Just replace the idler pulley as a unit, it is also called a belt tensioner. These things have a life about 350k miles and really should be replaced with the second belt, which has a life about 150k miles
shatteredsquare and feldsforever Thank this.
