Can someone please tell me the best and quickest method to pulp produce? Also, is there a thermometer which works better than others?
I'm a new driver with a company that hauls general freight to the west coast and and returns with produce to eastern cities. There are large notices in every trip pack instructing drivers to pulp the product every five hours, but I have yet to see it done and neither of the 2 trainers I been with could give me more than a roundabout answer when I asked how. I have always held myself to very high work standards and would like to bring that professionalism into this industry as well by doing the job the RIGHT way.
Thank you for your time....
Pulp Fiction (aka Reefer Madness)
Discussion in 'Questions From New Drivers' started by trailboss, Aug 30, 2007.
Get a digital meat thermometer, the kind with a probe (looks like a short knitting needle with a small box on the end). You can actually even find them in most truckstops. It will give you a fairly accurate reading, and do it quickly.
The best way really depends on the produce, I usually hauled lettuce (out of Salinas) so I basically had to temp death by stopping the loaders on forklifts so I could get a pulp temp. You do this by shoving the probe into the thickest part of the lettuce head (or bunch, if its romaine) and see what you got. And even after being run through the quick-chiller (think giant, liquid Nitrogen powered freezer) sometimes the temp is too high (since the produce is usually loaded right after picking).
Good luck with your reefer madness, just hope you don't get a load that's too warm, your reefer will run wide-open, then defrost 'cause the cooling coils are frozen. After 2 days of this, it will finally be in the normal temp range. -
Thanks for your reply.
I also haul out of Salinas and became concerned about it when my last trainer had to run two hours (daytime) across the Mojave without the cooling system operating because he let the reefer tank run out of fuel (I asked about the fuel level at the Pilot there and was told to mind my own business). -
Awesome, your trainer sounds like he's got it all together. When you get your own truck, you will get a feel for how much fuel the reefer burns, (which is also dependent upon what you're hauling) and you will hoepfully never run into the same problem.
And, once you fill the reefer up, you have to open the front panel and build the reefer motor's prime back up otherwise it ain't gonna start (as you two surely found out).
Goodluck with that trainer, keep us posted!
