Pump maintenance
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by spindrift, Nov 6, 2020.
  1. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    After a pump-off and wash, what are you folks adding to the pump to insure it doesn't freeze up on you if you plan on being in freezing conditions in the near future.
    I was thinking that I could use a good windshield washer fluid. Once I open the caps and let it drain I wouldn't think there would be enough fluid to contaminate the next load.
  3. Cat sdp
    Cat sdp . .
    20,957
    72,954
    Apr 8, 2012
    Orion's Belt
    Pam........
    spindrift Thanks this.
  4. LameMule
    LameMule Road Train Member
    1,147
    7,404
    Jan 19, 2020
    Montana
    I always left all valves open until the next load. It worked fine in -20 weather.
  5. bonder45
    bonder45 Road Train Member
    1,803
    5,450
    Oct 2, 2011
    Williston, ND
    I use -40 windshield washer fluid.
    Depending on what you put in your tank I may to a mix of windshield washer fluid and oil.
  6. RockinChair
    RockinChair Road Train Member
    5,085
    12,825
    Feb 19, 2012
    CC, TX
    Just dry it out completely before you shut the valves and replace the cap & plug. The product should be warmer than the ambient air temperature, so flooding the pump cavity before you start pumping will help warm it up a little.
    I loaded crude oil in 14°F weather (from an unheated tank) using a pump that had just been rebuilt, so it was clean and dry inside. All I did was open the inlet valve before starting the pump so that the pump wouldn't start dry.
  7. spindrift
    3,233
    12,905
    Dec 2, 2014
    Texas
    But the bypass inside the pump isn't going to dry out, will it?
  8. Cat sdp
    Cat sdp . .
    20,957
    72,954
    Apr 8, 2012
    Orion's Belt
    Unless you have a stainless pump the inside of the pump will rust after washing dry or not.......
    it’s best to lube it with something.......
  9. spindrift
    3,233
    12,905
    Dec 2, 2014
    Texas
    But Pam is too large to fit in that little space. ;)
    That's TX humor for 'ya.
  10. wis bang
    wis bang Road Train Member
    3,389
    3,985
    Jan 12, 2011
    Levittown, PA
    Matlack had a drain piped off the bypass to drain that part, removed the 1/4" plug and piped on a small ball valve.
    After washing we used compressed air to dry the pump. The Ropers used to spin a bit and you would see the drain valve spiting...
    Cap the pipes and let the drain valve open. always made a point to close it during the next day's pre-trip.
  11. mustang190
    mustang190 Road Train Member
    2,846
    6,115
    Jan 18, 2011
    Florida Panhandle
    Never had a problem with pumps freezing from ice.
    After a washout I just spin it for a second, cap them and that’s it.
    Normally the product being offloaded will be warm.
