Pump to fill rears and transmission
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Oct 12, 2019.
  1. Dino soar
    Dino soar Road Train Member
    4,791
    26,882
    Dec 8, 2017
    I was wondering what kind of pump you guys use to fill the rears and transmission.
    Do you use one pump for the rears and another separate pump for the transmission?
    I do have one pump that works but it has old gear oil in it instead of the newer style synthetic. What's the best way to clean that out?
  3. Collie
    Collie Guest
    i hop nobody gives me crap about this, but this will blow your mind. I bought this harbor freight 12v water pump a year ago to drain my 120 gallon fuel tank into a trash can to replace leaky valve under tank and then used it to refill the tank .
    Then i used it to empty 40 gallons of hydraulic fluid out of my hydraulic tank. into a drum and then refill it again.
    It emptied it like it was noones bussiness and refilled. Im not kidding either.
    I will be using it again on monday to refil 4 gallons of trans fluid back into my eaton trans on monday.
    What a dam good pump from harbor freight. I know the thicker oil will be hard onit but im sure i will pump it but hey i got my moneys worth out of it.
    12 Volt DC Transfer Pump
    Oxbow, Bean Jr. and Rideandrepair Thank this.
  4. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I have the pumps that go on 5 gallon buckets, one for each rears and trans. I have one that goes on a 16 gallon drum but don't use it anymore.
    I actually have 3 of the ones for 5 gallon buckets, and do not remember the costs, but they were not expensive. These are just hand pumps.
    Dino soar Thanks this.
  5. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    In the shop I have a nice Lincoln hand pump for each fluid keg. I also have a cheap 5gallon bucket pump that gets used for about everything. Road calls/reusing fluids/etc.
    Just get as much of the old fluid out as you can, give a couple pumps of the new fluid to waste, and fill what you need.
    Oxbow, Art Vandelay and Dino soar Thank this.
  6. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    Drill hole in bucket lid, pull a tight fitting hose through it and into the oil. Tie a weight to it if needed. Drill another hole for a valvestem, and use a bikepump to push the oil out.
    mhyn and Dino soar Thank this.
  7. Rideandrepair
    17,357
    56,317
    Aug 8, 2015
    Seems like I got a free hand pump, with the 5 gallon bucket of gear oil, when I bought it. Still had to rig up a funnel and hose to fill boxes.
  8. Dino soar
    4,791
    26,882
    Dec 8, 2017
    I've been looking at pumps I'm trying to figure what to buy, and a lot of this stuff is Chinese junk. A lot of people say that they have bought these lever pumps and they worked one or two times and then they leaked or had problems whatever.
    What you are suggesting is a great idea. When I get a chance I'm going to run to Home Depot and see if they have good lids that seal tightly for their containers.
    I'm sure I can make something similar with regulated shop air for a heck of a lot less money than a lever pump.
  9. Troy_
    Troy_ Road Train Member
    1,006
    6,633
    Dec 13, 2017
    Roma, Alberta.
    we've got the metal lids with the pump handle on each of the gear oil and trans oil pails, must be the good ones because they have been in use in our shop for over 30 years. I'm pretty sure they are Lincoln brand.
  10. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    Thanks for this thread. I'm planning to do this soon and was wondering what options I had for a pump.
  11. FoolsErrand
    2,877
    12,169
    Sep 15, 2017
    Ive transferred a few thousand gallons of wvo from 55gallon drums this way. Just remember its a big dang mess if you overpressure and pop something off. I painted half a barn and a whole dodge in like 3 seconds that one time.
    Oxbow, kemosabi49 and Dino soar Thank this.
