Push Pull control module
Discussion in 'Peterbilt Forum' started by HalpinUout, Jan 21, 2018.
  1. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,165
    Oct 2, 2011
    I'm hearing air leaking from behind Red/Yellow brake control module. What I'm wondering is on the back side once one of those push to connect fittings goes bad you have to replace the whole module piece correct? You can't just replace which ever push to connect fitting on the actual module that is bad? I'm looking at pictures online, haven't actually taken my dash apart yet to see. This is on a 587 Peterbilt.
    Shock Therapy Thanks this.
  3. buddyd157
    buddyd157 Road Train Member
    13,576
    34,885
    May 25, 2017
    under a shade tree
    i can olny say whenever mine went bad, the whole unit is replaced.
    HalpinUout Thanks this.
  4. Cat sdp
    Cat sdp . .
    21,060
    73,870
    Apr 8, 2012
    Orion's Belt
    Does that have a plastic dash.....?
    If it does, I’ve seen the dash get “ fatigued” and kind of cave in a little where the brake controls are.....
    Be prepared to do a little fabrication work putting it back together.
  5. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    That's what I'm thinking.
  6. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    Yes, I don't even see any screws or anything to take dash apart, I'm guessing I gotta take a flathead screw driver and start popping pieces off? Hopefully its easier than the actual brake valve that I changed a month or so ago.
  7. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    Just took a screw driver and did just that... Looks like that little piece comes right off... I'm going to mess with it tomorrow when I'm near a parts store. Something screws up out here where I'm at I'm screwed. LOL IMG_20180121_104950312.jpg
    4mer trucker and Shock Therapy Thank this.
  8. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    Another question? Is it pretty common part to be replaced on trucks when they reach a certain mileage/ amount of use? I'm at 460k on This truck.... or just "luck of the draw" type deal?
  9. buddyd157
    13,576
    34,885
    May 25, 2017
    under a shade tree
    no, i have had them go bad at any time/miles. might have to do with previous drivers and slamming them into the dash?
    or just poor quality parts.
    either way, i never really saw anything in specific change intervals.
  10. Cat sdp
    Cat sdp . .
    21,060
    73,870
    Apr 8, 2012
    Orion's Belt
    I had to put a small plate and some screws in because the plastic dash was f’d .....the trailer supply side is kinda funky but it’s solid.....
    I would agree don’t screw with it unless you have access to parts to put it back together.....
  11. Cat sdp
    Cat sdp . .
    21,060
    73,870
    Apr 8, 2012
    Orion's Belt
    Don’t know if this is yours or not.....
