pusher axle
Discussion in 'Ask An Owner Operator' started by thaley, Dec 25, 2014.
  1. thaley
    thaley Bobtail Member
    5
    This may be the wrong place but here goes. I have a single axle 92 00i international that I want to add a pusher axle to. Any advice on this would he great. Also does anyone know of a shop in Ga to get this done?
    Thanks in advance.
  3. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    Just to be sure here. A pusher goes in front of your current drive axle. The axle has a "U" in it to clear the driveshaft. A tag axle goes behind your current drive axle and usually means you have to extend your frame.
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    i would put a lift able pusher on, that way if you get stuck in the snow or something you can put all your weight on your powered axle or if you are empty or loaded really light you can run with it up.
    Cetane+ Thanks this.
  5. thaley
    5
    Yes ....I want a push axle that way if I do lift it I will still have weight on my steer tires
  6. thaley
    5
    Is there a considerable weight difference between name brands of pusher axles?
  7. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Look at Rowe Truck equipment in Indiana. They have a lot of experience in axles and frames and modifying trucks. I know it is not in Georgia, do google search, should be around Atlanta area for another shop that does the same thing.
  8. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    When GA. outlaw tri dump trucks alot were sold to repair shops that removed them, just start calling.
    double yellow Thanks this.
  9. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Hendrickson makes a killer liftable pusher if one is in the market for one. Depending on the application, they also have a control unit tied to it that reduces the air in the suspension on that axle in low traction situations to improve the drive axle traction without lifting the pusher. It is called the Optimax axle.
    http://www.hendrickson-intl.com/Truck/On-Highway/OPTIMAAX
  10. thaley
    5
    Thanks!! I will check it out!
  11. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
