Pushing a button to release trailer?
Discussion in 'Experienced Truckers' Advice' started by ethos, May 22, 2014.
  1. ethos
    ethos Road Train Member
    4,250
    10,816
    Mar 3, 2013
    Fort Worth
    I'm getting assigned a new truck soon and I got a chance to see it briefly. There is this button on the dash that says push to release kingpin or something to that effect. Now I'm sure it will be explained to me next week but I'm curious now. I was talking to some other drivers in the yard and they had no idea what it was. The fifth wheel has a release handle. Does this button override the handle, does it lock the handle in? There is a warning on the button that say pulling it will result in the trailer becoming uncoupled. Surely you can't just pull a button and drop your trailer on the street. In my 8 years I have never seen one of these things. Can anyone enlighten me?
    The button looks like one of those push to release the suspension air type things. In fact that is what I thought it was a first.
  3. TankerYankr
    TankerYankr Medium Load Member
    303
    470
    Jan 16, 2010
    Central US
    Perhaps it is for the fifth wheel slide?
  4. mitrucker
    mitrucker Road Train Member
    5,409
    9,992
    Dec 15, 2010
    Lapeer, MI
    It is a fifth wheel release. It only works when the parking brakes are applied. It only releases the fifth wheel, it will not lock it in. It comes in handy on snowy days and when everything is all muddy and nasty under there.
    ethos and EZX1100 Thank this.
  5. ethos
    4,250
    10,816
    Mar 3, 2013
    Fort Worth
    So to be clear, I pull the thing and I don't have to pull the handle? Also do I need to push it back in once I'm uncoupled?
  6. ethos
    4,250
    10,816
    Mar 3, 2013
    Fort Worth
    No, I have had one of those for years, never used it though.
  7. Feedlebum
    Feedlebum Light Load Member
    59
    39
    May 5, 2014
    That is nice to have just don't forget to get out and crank down the landing gear!
    Sly Fox and Moosetek13 Thank this.
  8. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    This thread wasn't what I expected. I was expecting "If you have to push a button to release your a steering wheel, then you are a _____________________."
    IS there air going to it? Hook to a trailer, then once your hear the jaws like, pull the brake brake, press the button and see if it releases. Maybe you can release the jaws with the handle OR the button?
  9. freightrunner
    freightrunner Heavy Load Member
    722
    182
    Mar 25, 2012
    Georgia
    Let me know if it's true so I can buy a heavy duty wrecker.
    Steeleandsonfarms Thanks this.
  10. ethos
    4,250
    10,816
    Mar 3, 2013
    Fort Worth
    I'm not going to pull any freight with it till next week so we will see then.
  11. mitrucker
    5,409
    9,992
    Dec 15, 2010
    Lapeer, MI
    What kind of truck is it? Mine was a Prostar. It had the switch you are describing. The parking brakes had to be applied in order for it to work. It does operate on air. When I pressed it there would be a beep that would change tone when the fifth wheel was released. You will have to press and hold the button until the jaws unlock. I didn't use mine very often. Only on the bad weather days.
