Qualcomm wiring
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by terrylamar, Apr 25, 2009.
  1. terrylamar
    terrylamar Road Train Member
    1,023
    368
    Oct 8, 2006
    Austin, TX
    Is anyone familiar with the wiring on a qualcomm? My message notification beep does not beep. I am assuming that there is a wire that is not connected. I can see the wiring harness and there are several wires that have been cut into. I could connect these wires and perhaps randomly find the correct one through trial and error, but I don't know what any of these wires do, so I am recluctant to connect any of them.
    I was told that some of our trucks have a switch added that turns off the message beeper. Mine doesn't, this is why I am assuming that the wire is not connected.
  3. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    My unit had a button on the keyboard that controlled the sound.
  4. terrylamar
    1,023
    368
    Oct 8, 2006
    Austin, TX
    Yes, mine has that also, but I am talking about the incomming message beep. That is seperate.
  5. Roadmedic
    18,951
    8,981
    Apr 4, 2007
    My volume controlled the incoming beep.
  6. terrylamar
    1,023
    368
    Oct 8, 2006
    Austin, TX
    Your volume control, controlled the volume. It does not turn it on or turn it off. You can turn your volume all the way down and stick your ear by the keyboard and still hear the beep. If I wanted to, I could go into the keyboard and disconnect any button. Then the volume control wouldn't control the volume of that particular key. I am asking about the wiring for the incomming message beep, not it's volume, the fact that it get a signal at all.
  7. Roadmedic
    18,951
    8,981
    Apr 4, 2007
    I would guess it would be something controlled by the company.
    Have you googled it?
  8. terrylamar
    1,023
    368
    Oct 8, 2006
    Austin, TX
    It is not controlled by the company, unless they snipped the wire. I just need to know what color the wire is so I can splice it.
    Yes, I have googled it.
  9. skibum_63
    skibum_63 Road Train Member
    2,176
    918
    Oct 12, 2007
    somewhere, USA
    It could of been programed , not to beep, when the unit was installed.
    Did it beep before?
    If your a company driver, i wouldn't mess with it. Companies are looking for the smallest reason to get rid of people.
  10. Red Fox
    Red Fox Road Train Member
    1,316
    432
    Jan 26, 2009
    Acworth, Ga.
    With wires cut it sounds like someone allready DID mess with it. And if you tell the company about it, they're likely to blame you for it, so you're probably doing the right thing, trying to fix it yourself. Obviously you're trying to NOT play with the wrong wires.
    ...now c'mon and tell us...you've been playing around with it, haven't you? :munky2:
  11. terrylamar
    1,023
    368
    Oct 8, 2006
    Austin, TX
    I am not a company driver. The shop told me some units had a switch installed to turn off/on the message notification beep. I am assuming the wires were cut, but the switch was not installed.
